HD audio converter file format and resolution (software)
audiventory
  • Yuri Korzunov, AuI ConverteR 48x44 developer
    • AuI ConverteR 48x44 - HD audio converter for high resolution files
What Is DSD Audio?
« Reply #140 on: 29 Dec 2017, 01:37 pm »
Read quick explanation what is DSD audio? https://samplerateconverter.com/educational/what-dsd
audiventory
DSF to DFF Converter [Mac, Windows]
« Reply #141 on: 1 Feb 2018, 05:15 pm »
DSF to DFF Converter [Mac, Windows]: Read about quality issues, key features, quick start and other https://samplerateconverter.com/dsf/dsf-dff-converter
audiventory
DSD vs FLAC
« Reply #142 on: 4 Feb 2018, 05:44 pm »
DSD vs FLAC [Comparison, Infographic, Comments to the picture] https://samplerateconverter.com/educational/dsd-vs-flac
audiventory
How to convert FLAC to ALAC on Windows, Mac OS
« Reply #143 on: 15 Feb 2018, 03:59 pm »
https://samplerateconverter.com/flac/convert-flac-alac
audiventory
CD to FLAC Converter for Mac, Windows
« Reply #144 on: 16 Feb 2018, 01:57 pm »
CD to FLAC Converter for Mac, Windows [Safe Ripper]
https://samplerateconverter.com/cd-ripper/cd-flac-converter
audiventory
R2R Ladder DAC vs Sigma-Delta DAC vs DSD DAC
« Reply #145 on: 25 Feb 2018, 05:29 pm »
Read about comparison of R2R Ladder DAC vs Sigma-Delta DAC vs DSD DAC [ Infographic Inside ] https://samplerateconverter.com/educational/r2r-ladder-dac-vs-sigma-delta
audiventory
DSD vs FLAC [Audio Format Comparison and Explanation]
« Reply #146 on: 27 Feb 2018, 06:15 pm »
DSD vs FLAC [Audio Format Comparison and Explanation] https://www.youtube.com/watch?v=UWcHpRbwuu4
audiventory
NOS DAC. Non-Oversampling DAC [Advantages, Disadvantages]
« Reply #147 on: 11 Mar 2018, 04:15 pm »
Read about NOS DAC. Non-Oversampling DAC [Advantages, Disadvantages] https://samplerateconverter.com/educational/nos-dac
audiventory
Re: HD audio converter file format and resolution (software)
« Reply #148 on: 21 Apr 2018, 06:11 pm »
DSD music stores links are collected here (on 2018). Check free sample links https://samplerateconverter.com/educational/dsd-music
audiventory
What is DSD audio
« Reply #149 on: 29 Apr 2018, 05:23 pm »
PCM was discussed many times. But author hope, that you learn something new here. Read about sound quality matters, myth reasons and other in simple words https://samplerateconverter.com/educational/pcm-audio
audiventory
DSD software player list
« Reply #150 on: 5 May 2018, 05:10 pm »
Look at DSD software player comparison list (Windows, Mac, Linux, Android, iOS) https://samplerateconverter.com/educational/dsd-player
audiventory
The best audio file format
« Reply #151 on: 19 May 2018, 04:52 pm »
Read and look at infographic how to choose the best audio file format for you https://samplerateconverter.com/educational/best-audio-file-format
maty
« Reply #152 on: 19 May 2018, 05:23 pm »
Hi from Spain,
Weeks ago I tried your soft (trial) to make FLAC 24/192 -> FLAC 24/96 and the new sound is very good, congratulations. With very good recordings and high DR off course.
In my system, very optimized to play multimedia, I can easy detect the differences between MP3 320 kbps, Ogg q9 or q10, FLAC 16/* and FLAC 24/*.
I have a question:
And between FLAC 0 and FLAC 4 or 8 too <- What do you think it is due to?
I have a lot of questions. Maybe a new thread.
audiventory
« Reply #153 on: 19 May 2018, 05:31 pm »
Hi from Russia,
Thank you for kind words, Maty.
FLAC contains absolutelly identical binary content for any compresion level (including uncompressed FLAC).
There is hypthesis, that FLAC upacking can cause additinal consuming of computer resources and additional noise in the audio system.
It may be observed via spectrum analyzis of analog output of DAC. But still nobody show it.
So while no safe evidences, that compressed FLAC cause some quality issues.
And you can use optimal for you comression level.
Best regards,
Yuri
maty
« Reply #154 on: 19 May 2018, 05:39 pm »
Yes, I have the same hypothesis, the CPU load. More load -> more noise.
More incredible, if I make a special degrag of the audio files the sound is better, without a doubt. The CPU load must be the same if not equal. Your hypothesis?
Now: i5 4460.
audiventory
« Reply #155 on: 19 May 2018, 05:43 pm »
It is not my hypothesis. I read it in one of FLAC discussions.
Unfortunatelly, I have no proper hardware spectrum analyzer to execute experiment.
Also it may depend on system, if the hypothesis will proved even.
maty
« Reply #156 on: 19 May 2018, 06:00 pm »
Why almost all music from digital masters between 80's and late nineties sound bad or not as well as they should?
Most of the music that gets me excited comes from analog masters before the eighties.
My hypothesis is that the old ADC/DAC and clocks added a lot of jitter to the master. What do you think?
audiventory
« Reply #157 on: 19 May 2018, 06:18 pm »
It is need to learn each system [from ADC to DAC] for jitter.
I suppose, modern CDs are recorded, mixed in high resolution on powerful computers. It give higher sound quality, than elder CDs.
High resolution give more opportunities to reduce measurable distortions in audible range. These things may be observed objectively.
There is huge distange between digital music production devices in 80's (and 90's even) and current ones.
I played in bands since 80's. If look from 80's/90's, current equipment/software like to miracle :)
maty
« Reply #158 on: 20 May 2018, 09:46 am »
After many tests, usually with this recoder said recordings improve or do not sound to bad. When 24/96 -> 24/96 or 24/192 -> 24/96. FLAC 0 1024 kpbs.
[IMG] http://maty.galeon.com/WP-imagenes/foobar2000/foobar2000-convert-profiles-sssrc-96-intermediate-93_9.png
Until a month ago, before my last optimizacion, the pass band at 95%
The master clocks of these years had a lot of jitter -> jitter in the digital master -> jitter in cassette, CD, vinyl...
Off course, the new softs are much better.
And, with your soft the sound is better than SoX or SSRC with these bad recordings or older/modern too!
audiventory
« Reply #159 on: 20 May 2018, 10:01 am »
Thank you for feedback and kind words, Maty! :)
In AuI ConverteR for each of input/output sample rate combinations, individually and manually adjusted filters are used. May be it give improvement.
May be ultrasound elimination give effect too.
