HD audio converter file format and resolution (software)
0 Members and 1 Guest are viewing this topic. Read 87919 times.
audiventory
  • Yuri Korzunov, AuI ConverteR 48x44 developer
    • AuI ConverteR 48x44 - HD audio converter for high resolution files
Article: Multiple vs. Non-Multiple Resampling Audio
« Reply #120 on: 18 Jul 2017, 08:43 pm »
Standard audio sample rates are based on 44.1 and 48 kHz. Somebody think that multiple resampling (integer multiplication/division) have lesser distortions than non-multiple one. Read below about difference between both resampling types http://samplerateconverter.com/educational/resampling
audiventory
7 Keystones of Accurate HiFi Blind Test [Article]
« Reply #121 on: 22 Jul 2017, 05:30 pm »
The test is way of "objective" measurement of "subjective" perception. Read about most important things that can turn a HiFi test into a safe evidence http://samplerateconverter.com/educational/hifi-blind-test
audiventory
Power Conditioner for Audio. It's real advantage? [Article]
« Reply #122 on: 28 Jul 2017, 11:58 am »
Power conditioner is one of audio equipment, whose action can be demonstrated easiest way. Read what happens into an audio module with and without the power conditioner. http://samplerateconverter.com/educational/power-conditioner
audiventory
Can audio tests be objective? [Article]
« Reply #123 on: 3 Aug 2017, 05:56 pm »
There are 2 definitions of audio quality: objective and subjective. But can audio quality be fully objective? http://samplerateconverter.com/educational/audio-test-objective-subjective
audiventory
Re: HD audio converter file format and resolution (software)
« Reply #124 on: 9 Aug 2017, 07:22 pm »
Read in this article, that is voltage, in context of audio as physics part http://samplerateconverter.com/educational/voltage-audio
audiventory
« Reply #125 on: 22 Aug 2017, 07:48 pm »
audiventory
« Reply #126 on: 2 Sep 2017, 06:36 pm »
Some people try estimate audio equipment and software quality via spectral analysis of a music. Read in the article about technical issues of such tests http://samplerateconverter.com/educational/music-sound-quality-test
audiventory
[Audio Physics for Beginners]
« Reply #127 on: 7 Sep 2017, 07:15 pm »
audiventory
« Reply #128 on: 15 Sep 2017, 06:11 pm »
New AuI ConverteR 48x44 v.6.7. Crash Issue Is Fixed http://samplerateconverter.com/content/aui-converter-48x44-v67
audiventory
« Reply #129 on: 20 Sep 2017, 05:57 pm »
DSD is one of high resolution audio formats. Read about important DSD issues http://samplerateconverter.com/educational/what-is-dsd-audio
audiventory
« Reply #130 on: 26 Sep 2017, 05:11 pm »
Read how to choose the best format to rip CD audio http://samplerateconverter.com/cd-ripper/best-format-rip-cd
audiventory
DSD vs DSF vs DFF Files Audio. What is difference [Article]
« Reply #131 on: 3 Oct 2017, 06:08 pm »
Read about difference between DSD, DSF, DFF files audio: quality, playback, metadata issues http://samplerateconverter.com/educational/dsd-dsf-dff-audio
audiventory
« Reply #132 on: 6 Oct 2017, 01:13 am »
How to Rip a CD Audio on Mac OSX and Windows [Step-by-Step Guide] http://samplerateconverter.com/cd-ripper/how-rip-cd-audio
audiventory
« Reply #133 on: 10 Oct 2017, 04:06 pm »
Rip Audio CD. Read answers to Frequently Asked Questions http://samplerateconverter.com/cd-ripper/rip-audio-cd-faq
audiventory
« Reply #134 on: 17 Oct 2017, 12:32 pm »
Read answers to frequently asked questions about 1-bit audio ISO to DSF conversion of audio files http://samplerateconverter.com/educational/iso-dsf-faq
audiventory
« Reply #135 on: 24 Oct 2017, 05:51 pm »
New audio converter music files ISO, DSF, DFF, WAV, FLAC, AIFF, mp3, m4a and other AuI ConverteR 48x44 v.7.0 (major update) is released 24 October 2017 http://samplerateconverter.com/content/new-aui-converter-48x44-v70-released
audiventory
« Reply #136 on: 26 Oct 2017, 02:56 pm »
We implemented uncompressed FLAC in AuI ConverteR v.7.
Read user guide: comparison table WAV vs. uncompressed FLAC, settings, uncompressed FLAC size issues http://samplerateconverter.com/flac/flac-uncompressed
audiventory
DSF vs PCM. What is common base? [Article]
« Reply #137 on: 7 Nov 2017, 02:23 pm »
DSD and PCM are considered as different formats, as rule. Read why author think, that PCM and DSD are two side of a single phenomenon http://samplerateconverter.com/educational/dsd-vs-pcm
audiventory
What Is Dynamic Range Audio? [Guide For Beginners]
« Reply #138 on: 24 Nov 2017, 12:30 pm »
What Is Dynamic Range Audio? [Guide For Beginners]. Read about methods of measurement and its difference https://samplerateconverter.com/educational/dynamic-range
audiventory
DSD DSF DFF Editor Software
« Reply #139 on: 14 Dec 2017, 07:40 pm »
DSD editor software [audio quality and implementation issues] https://samplerateconverter.com/educational/dsd-dsf-dff-editor
