HD audio converter file format and resolution (software)
0 Members and 1 Guest are viewing this topic. Read 97884 times.
audiventory
  • Yuri Korzunov, AuI ConverteR 48x44 developer
    • AuI ConverteR 48x44 - HD audio converter for high resolution files
Re: HD audio converter file format and resolution (software)
« Reply #20 on: 29 Nov 2014, 08:19 pm »
2014 November 29 released AuI ConverteR 48x44 v.3.8.33. Fixed some bugs and improved sound quality DFF, DSF conversion http://samplerateconverter.com/content/new-aui-converter-48x44-3833-fixed-bugs-dff-dsf-conversion
audiventory
HD audio converter DSF D256/512
« Reply #21 on: 22 Dec 2014, 02:06 pm »
New audiophile music file converter with DSF (1-bit D64/128/256/512) file format supporting. Version 4.0 released.
http://samplerateconverter.com/content/new-audiophile-music-file-converter-aui-converter-48x44-v-40
audiventory
DSF meta tag editor (Windows and Mac OS X)
« Reply #22 on: 17 Jan 2015, 01:53 am »
Released new beta AuI ConverteR 48x44 (Mac OS X, Windows) with built in metatag editor DSF audio files (1-bit / D64/128/256/512).
Edit text and picture Fields. In single DSF file can inserted several pictures: album covers front, back, ...
Metatag editor available in FREE edition.
http://samplerateconverter.com/content/dsf-meta-tag-editor-audio-converter-aui-converter-48x44
audiventory
« Reply #23 on: 30 Jan 2015, 06:56 pm »
New high resolution audio converter AuI ConverteR 48x44 v. 4.1.2. Fixed several bugs of reading native AIFF metatags and added advance reading id3 metatags. http://samplerateconverter.com/content/new-aui-converter-48x44-412-fixed-some-bugs-reading-aiff-and-id3-tags
audiventory
« Reply #24 on: 31 Jan 2015, 09:06 pm »
New high resolution audio converter AuI ConverteR 48x44 v. 4.1.3. Improved algorithm adaptation for reading non-standard id3 meta tags. http://samplerateconverter.com/content/new-aui-converter-48x44-v413-more-adaptation-non-standard-id3-tags
audiventory
« Reply #25 on: 10 Feb 2015, 06:13 pm »
New high resolution audio converter AuI ConverteR 48x44 v. 4.1.5. Supported reading and writing WMA metadata and export album artworks from source file folder http://samplerateconverter.com/content/new-aui-converter-48x44-v415-support-wma-metadata
audiventory
« Reply #26 on: 19 Feb 2015, 03:13 pm »
During converting some albums (operas, symphonies, live concerts) need provide gapless transient between tracks. True Gapless Conversion (TGC) allow avoid both these troubles about border of two tracks. http://samplerateconverter.com/content/true-gapless-conversion-audio-files
audiventory
« Reply #27 on: 5 Mar 2015, 07:30 pm »
Released AuI ConverteR 48x44 v. 4.1.12:
- Clickless converting ISO (1-bit audio) to DSF/WAV/AIFF/FLAC/... via DFF for better gapless ability of some albums.
  Metadata transferred via CUE file extracted from ISO.
- Faster close speed of Settings window after canceling.
- Multichannel/stereo extract switcher added to Settings window / Parameters tab.
- Fixed some issues of stability
More detail here http://samplerateconverter.com/content/how-convert-iso-dsf-wav-etc-without-clicks-mac-os-x-and-windows
audiventory
« Reply #28 on: 12 Apr 2015, 04:01 pm »
More stability of reading CD database, ISO Conversion Control. New AuI ConverteR 48x44 v.4.1.20 Read more
audiventory
« Reply #29 on: 15 Apr 2015, 04:32 pm »
ANALYSIS: DSD-to-PCM 2015 - foobar SACD Plug-In, AuI ConverteR, noise & impulse response...
http://archimago.blogspot.ru/2015/04/analysis-dsd-to-pcm-2015-foobar-sacd.html?showComment=1428926408403#c6196240508548468877
audiventory
« Reply #30 on: 16 Apr 2015, 05:52 pm »
Applied 3rd generation filters for all input / output sample rates 44 kHz http://samplerateconverter.com/content/new-aui-converter-48x44-v4122-applied-3g-resampling-filters-441-khz
audiventory
« Reply #31 on: 1 May 2015, 12:24 pm »
New AuI ConverteR 48x44 v.4.2.1. Fixed launch crash for some conditions http://samplerateconverter.com/content/new-aui-converter-48x44-v421-fixed-launch-crash-some-conditions
audiventory
« Reply #32 on: 9 May 2015, 08:14 pm »
New high resolution audio converter AuI ConverteR 48x44 v. 4.3. Applied all 3G (third generation) resampling filters. Improved stability of sigma delta modulator (DSF output files) http://samplerateconverter.com/content/new-aui-converter-48x44-v43-applied-3g-all-resampling-filters
audiventory
« Reply #33 on: 15 May 2015, 05:41 pm »
New AuI ConverteR 48x44 v.4.3.2. Compressed DFF decoder linking ability http://samplerateconverter.com/content/new-aui-converter-48x44-v432-compressed-dff-decoder-linking-ability
audiventory
AuI ConverteR is not simple sample rate converter. But it is sound optimizer for digital-analog converter.
In version 4.3.15 applied traditional high definition sample rate conversion mode too. Now possible select one of these modes.
DSF filters don't modified.
http://samplerateconverter.com/content/new-aui-converter-48x44-v4315-traditional-sample-rate-conversion-mode
Nick B
« Reply #35 on: 19 Jun 2015, 05:39 pm »
Hello Yuri,
I have been on your website and checked out the YouTube  video. Looks like great software!  Right now, I  have 2 dacs that are only 16/44 capable and I don't know if I'll be buying new dacs that are capable of more. I have some 16/44 cd's that have lots of noise and will also be doing a/d conversion of my many albums including 78's. Can I simply use your software for reducing noise only in the 16/44 domain without doing any up sampling?
Also, regarding tagging, what databases do you use? I have lots of obscure cd's that are difficult to tag.
Nick
audiventory
« Reply #36 on: 19 Jun 2015, 07:46 pm »
Hello Nick,
Thank you for kind word!
Sample rate as itself don't provide sound quality.
As example, pro 44/16 DAC with better components and better tuned can sound better more cheap 192/24 DAC.
Exists several measured criterias that can used as hi-end features of hardware.
But without measurement tools impossibly check it home.
And I always recommend check sound on hear before buying.
Also measurement don't cancel hearing control.
I suppose the noise distributed in range 0 … 22 kHz.
AuI in optimized mode do deep filtration with transient band 20 … 22 kHz.
However I don’t sure that it reduse noise in your case.
Anyway you can try use free demo. There quality is not limited.
I special do it for possibility full sound check of my software before buying.
As CD database as default used freedb.org. Possibly musicbrainz.org will work too.
Able set database at CD ripper settings:
Settings window / CD ripper/ISO tab / CDDB reading parameters
I consider possibility add gracenote  support.
But while don’t know how provide for AuI's users suitable work due don’t know, how fit gracenote’s payment model.
Best regards,
Yuri
audiventory
« Reply #37 on: 29 Jun 2015, 06:18 pm »
New AuI ConverteR 48x44 v.4.3.19. Fixed some troubles of launching coders decoders http://samplerateconverter.com/content/new-aui-converter-48x44-v4319-fixed-some-troubles-coders-decoders
audiventory
audiventory
« Reply #39 on: 10 Jul 2015, 07:24 pm »
