HD audio converter file format and resolution (software)
JohnR
Re: HD audio converter file format and resolution (software)
« Reply #60 on: 6 May 2016, 08:51 am »
Hi Yuri, your page is a bit hard to follow. Will it convert multichannel DSD to (multichannel) FLAC?
audiventory
  • Yuri Korzunov, AuI ConverteR 48x44 developer
    • AuI ConverteR 48x44 - HD audio converter for high resolution files
« Reply #61 on: 6 May 2016, 09:48 am »
Hi John,
Thank you for reply. I will try to make my site's pages clearer.
AuI ConverteR support conversion multichannel ISO/DFF/DSF to FLAC (number input channels = number output channels) in editons:
1. DEMO,
2. Audiophil-E, PROduce-R, PROduce-RD
3. Modula-R (see Easy Configurator http://samplerateconverter.com/mscn/modula-r-configurator.php )
There need modules:
a) ISO, DSF, DFF (D64/128) > FLAC : [ISO extract (core)] + [input D64/128 (add-on)] + [Base (core)]
b) DSF, DFF (D64/128) > FLAC : [input D64/128 (add-on)] + [Base (core)]
For support D256/512 also need module [input D256/512 (add-on)].
audiventory
What is optimization audio for DAC
« Reply #62 on: 22 May 2016, 03:51 pm »
In the article considered issues of digital analog conversion audio and ways for improving quality of conversion.
audiventory
audiventory
« Reply #64 on: 2 Jun 2016, 06:30 pm »
New AuI ConverteR 48x44 v.5.6.17 Auto Updater Applied. Now the converter will check last update, download new installer and run it http://samplerateconverter.com/content/new-aui-converter-48x44-v5617-auto-updater-applied
audiventory
« Reply #65 on: 5 Jun 2016, 01:26 pm »
Audio Converter ISO to FLAC, AuI ConverteR’s optimal configuration issues, User manual http://samplerateconverter.com/content/audio-converter-iso-flac-aui-converter%E2%80%99s-optimal-configuration-issues
audiventory
« Reply #66 on: 7 Jun 2016, 07:00 pm »
1. Audio Converter ISO to DSF - AuI ConverteR optimal configuration issues. User manual.
http://samplerateconverter.com/content/audio-converter-iso-dsf-aui-converter-optimal-configuration-issues
2. Today released update 5.6.18. Fixed issues creating target directory by metadata during ISO to FLAC conversion.
Use auto update functionality, please.
audiventory
« Reply #67 on: 10 Jun 2016, 07:35 pm »
audiventory
« Reply #68 on: 17 Jun 2016, 04:33 pm »
audiventory
« Reply #69 on: 21 Jun 2016, 02:03 pm »
AuI ConverteR 48x44's DSF to FLAC conversion in details Audio Converter DSF to FLAC - AuI ConverteR 48x44
audiventory
« Reply #70 on: 23 Jun 2016, 07:48 pm »
FLAC to DSF Audio Converter - AuI ConverteR 48x44. User manual: http://samplerateconverter.com/content/flac-dsf-audio-converter-aui-converter-48x44
audiventory
« Reply #71 on: 8 Jul 2016, 05:43 pm »
New AuI ConverteR 48x44 v.5.7.1 Skipping Pauses for Conversion ISO http://samplerateconverter.com/content/new-aui-converter-48x44-v571-skipping-pauses-conversion-iso
audiventory
« Reply #72 on: 18 Aug 2016, 06:47 pm »
AuI ConverteR 48x44 v.5.8. Demo with batch processing, DFF output (Windows only), DSF CUE splitter. Read more...
audiventory
« Reply #73 on: 31 Aug 2016, 06:46 pm »
Released new high resolution audio converter AuI ConverteR 48x44 v. 5.8.3 CD ripper, ISO, DFF, DSF, WAV, FLAC, AIFF, ALAC. Fixed ISO conversion issues, added national encodings for parsing CUE files, fixed some minor bugs.
Read more >>
audiventory
audiventory
audiventory
audiventory
« Reply #77 on: 26 Sep 2016, 04:51 pm »
New AuI ConverteR 48x44 v.5.8.9. Fixed Issue of ISO Extract Non-correct Temporary Directory Creating http://samplerateconverter.com/content/new-aui-converter-48x44-v589-fixed-issue-iso-non-correct-temporary-directory
audiventory
« Reply #78 on: 9 Oct 2016, 12:57 pm »
audiventory
« Reply #79 on: 24 Oct 2016, 05:31 pm »
Studio Audio File Converter AuI ConverteR 48x44 6.0 Released
1. Support 705 and 768 kHz input and output sample rates for WAV and AIFF files.
2. Safe CD ripper with additional recovering abilities under Windows.
3. Performance is improved for intensive logging.
For version 6.x planned other improvements.
Read more http://samplerateconverter.com/content/studio-audio-file-converter-aui-converter-48x44-60-released
