0 Members and 1 Guest are viewing this topic. Read 60297 times.
Great posts Pneumonic..it stimulates the mind..but i have to say this...even a straight piece of wire can induce current (signal) as an antenna ...it is electric!!now i leave you guys alone again..
A few people commented on their lack of need for power, and it is that very thing that had me looking at this thread. For years, I've always had more amp than I've needed.I just went over the demand cliff this week, when I took delivery on a pair of Cornwalls (First Model). Even with Rothwell attenuators in the signal chain, the furthest the Knob on my Peachtree Audio Nova (60 Watts per side at 8 Ohms) has to go is about 11 o'clock to get uncomfortably loud. So, I'm looking for a replacement. After I get some things sorted out with the speakers (re-terminate my speaker cables, and I think the crossovers need to be either rebuilt or replaced), I need to figure out if I can get a demo of a couple of these amps to plug in to my system...This thread has been a great help. A lot of great information throughout. My thanks to all.
Please tell us more about your system details. For instance the sensitivity of the Cornwalls (which i know is high), the attenuation of the Rothwells and how they are in the system. Which Peachtree model do you have? How loud do you listen?What do you plan to do to the crossovers? I know Paul K often used electrolytic crossover caps. That is one place where cap quality (MATERIAL) can make a big difference. As you may know I am not a cap crazy guy and there are good quality caps that are not expensive.What sort of amps are you considering? You now have a speaker that can use low power.
Those are fancy crossovers. I see they have litz-wire chokes which is rather unnecessary and expensive. We make the 245 amp to order only and its over $2000The EM7 is in your range and there is a kit of the mono 2.5 per channel if you want to save money. It will play your speakers cleanly to 100-103 dB peaks at 1 meter. We do have a pair of EM7 push pull monos in stock for $2500 (list) that you could have for $2000 as a audiocircle member. It will play them much louder and lower distortion as it is push pull and class A cathode biased.
Yeah, fancy is a good word. Their mid- and high-level offerings introduce more variables than I really want to mess with. Their low-end provides a little more than the usual, and would help quite a bit. Their inclusion of air-core inductors confuses me...I am not kit adverse (I guess my Weller will still fire up, if I can find it...) I was passing over your 2.5 Watt models because I was concerned about not having enough grunt if I want to get loud. Your stated output numbers put that to rest, and add another option.And that is very generous of you to provide AC member pricing of the push-pull monos. The price list indicates they use a balanced input. Do they have an unbalanced as well? That's what the pre-outs on my Nova are.
For a start why not just replace the leaking capacitors with good polypropylene. Nothing fancy, under $10 a cap unless they are really big values. A good balanced input works just as well unbalanced via an adapter. The amp also has low gain so you can run your volume control higher... which we know is good. You will probably be able to get rid of your attenuators.
Let's get back to class-a,this thread has been derailed,what are the pros or conssmall class-a amplifiers can be build with easy,so why not if you love themforget about the heat if it's a small one,class-ab do it all the time they too consumesome heat when in class-a for some part,Roger is right when he mentions low wattclass-a they certainly make a difference with sensitive speakers..
Ultimately, each person will decide for themselves whether or not to accept, or not, whatever negatives are associated with the heat their amps dissipate. It's not just about wasted $$$$ in terms of electricity but heat has been known to cause premature failure of electronic componetry if not dissipated properly. And then we have issues of unrealistic applications. My speakers take a minimum of 300w to even turn on and close to 1kw to sing gloriously. It would be folly for me to use a class A in such setup. Of note, even though my amps all produce in excess of 1/2kw, they are extraordinarily efficient. At idle, no more than 4w and even pushed to extremes, they only ever get warm to touch. Electricity and heat related issues are absolutely a non factor for me.
The Electrocompaniet AW2-120 is a outstanding 120 watt per channel Class A Balanced Amplifier. One of the best sounding SS amps I've heard regardless of price. IMHO, it sounds better than the Pass Labs XA30.5 (which is no slight to the Pass Labs amp whatsoever). http://www.electrocompaniet.com/products/classic/poweramp/2x120-M.html
Perhaps you should tell us more about your system, Those are big numbers and a very low idle. What is the going price for the Electrocompaniet?
Your speaker situation is unique, to say the least. The ATC speakers are 85db/w, and the EC AW2-120 drives them to ear-splitting levels if so desired (cleanly, I may add). A properly designed amp, regardless of class of operation, will last a long time.
Indeed, they will last awhile if designed properly. Unfortunately, in some instances, such as mine, if I were to employ suitable class A amps, I'd be needlessly dissipating a kw of power. Even though I'm in a relatively cold climate here in Canada, our summers get toasty such that my system would be unlistenable for a few months of the year. To speak nothing of my unimaginably high electricity costs .... which wouldn't please the missus any
In your case, class A makes NO sense. You need lots of clean pristine power for those outstanding speakers you have.
