0 Members and 1 Guest are viewing this topic. Read 61060 times.
Gished? Whats that?
I dont listen to JayZ either but it was an example given to me by a younger person. It's what the next generation is listening to.
I agree class A is wasteful and not always the best sound.
I meant to comment on the amp you mentioned. I looked at their website and found the idle power of 130 watts and output power of 40 watts but no statement if that's 40 per channel or 40 total watts.
If the peak is 40 dB above the average then what level is your average SPL? If your average SPL is 80 dB then your peak is 120 dB SPL. What does that sound like?
A problem with class-a and dynamic range,basicly there are limitations on the lower end of music (with hum)
....and the higher end of music (with o/p watts)
Unlike back in the day, today's modern transistors have crazy good power capability and extraordinarily linear transfer functions which allows for the ability to design for (high) power outputs, with inaudible distortion levels
Fellas. I can bias any modern transistor so that, just turning on, the measured distortion level will be say 0.5%. If I heavily bump up the bias current I can get #’s down to about 0.05%. But this would be a very wasteful design as it would be needlessly dissipating oodles of power. The last heavy bias amp I did it was disappointing around 50w. That's crazy! That same design, with the bias down to about 5w waste, gave me distortion #'s in the 0.3% range. Still way below audible amounts. Keep in mind this is all without any NFB! But we all love lower distortion #’s so, by properly compensating with minimal amounts of local feedback, the #’s can get down into the 0.001% range – a thousand times below our hearing limit.
The "problem" is finding a HE speaker that provides reasonable linearity across the entire frequency band.
There is a damn good reason many of the high end speakers that measure reasonably flat across their spectrum are in the mid 80's spl or so.
And it will still sond like crap unless you design it correctly:http://www.jockohomo.net/data/7470.pdf
The physics underlying all amplifying devices has not changed. Transistors are still inherently the highest distortion devices out there, with the possible exception of Nelson Pass's custom made SIT's. The old direct heated triodes (300B, 2A3, 845 etc), are still the lowest distortion amplifying devices extant.
John Atkinson's measurements and comments at the end are always a treat. I know many readers do not bother with the measurements section as it is just too techy. However I encourage all to read the last paragraph where JA gives his very honest opinion and often muses why a poor performing amps is so loved by the reviewer. That amp does look pretty good all in all. I am however surprised that it doesn't do better into low impedance loads given that it has 3 pairs or outputs per channel. It would have been a nice design feature to have it provide high current for those who need it.
http://www.cordellaudio.com/papers/another_view_of_tim.shtmlAudiophile myths never die...
2 second search:http://www.diysoundgroup.com/catalog/product/gallery/id/332/image/1042/http://www.gedlee.com/summa_.htmOf course if you're looking in all the wrong places, like glossy audiophile mags, that may indeed be a "problem"....Now the goal posts can shift to size, looks, etc, in 3,2,1... Yes, it's called Hoffmans Iron Law...and a market based on fashion trends.cheers,AJ
What a shock, engineers disagree to some extent about the best overall design.
[/color][/i]Anyone who has actually listened to equipment with these design principals incorporated will hear the results.
The "problem" is finding a HE speaker that provides reasonable linearity across the entire frequency band. The claims made on a website have little to do with actual performance.
There are also space restrictions in many cases.
