0 Members and 1 Guest are viewing this topic. Read 61013 times.
Cordell debunked the NFB>TIM myth. That's a bit more than a "disagreement". Interesting. Please provide the links so we can see the specifics, controls used, statistical analysis of the positives, etc. TIA.
http://www.stereophile.com/content/boulder-500ae-power-amplifier-transient-intermodulation-distortion
Sidebar 2: Transient Intermodulation DistortionTID is due to the active devices being unable to slew the voltages they are asked to handle sufficiently fast to keep up with the demands of the signal. —J. Gordon Holt
The article discusses the origins of TIM and the transient nature of music that can bring it on. It points out that amplifiers with inadequate slew rate margin are the ones prone to TIM. Moreover, the article demonstrates that large amounts of negative feedback, when properly applied, do not in any way contribute to TIM. The bad rap that negative feedback gets to this day is largely a result of that misconception.- Bob Cordell
None other than Nelson Pass has cited the work regarding TIM and it's importance, as has John Curl.
Appeal to Authority in no way addresses the facts Cordell presented. But the myth of NFB is "audiophile" by nature, thus immune to facts.If you have some evidence of TIM/slew issues in modern amps, or NFB causing drama, including those biased Class A (as the thread topic implies) please do present it. Thanks.cheers,AJ
Denying TIM is like denying men landed on the moon!
Fixation on it and incorrectly correlating it to NFB, is an audiophile thing. Myths persist. If it has any relevance, then you should have no problem citing some modern day examples. Feel free to go back to the 90s if needed. TIA.Otherwise, yet another audiophile tempest in a teapot.http://sound.westhost.com/articles/distortion+fb.htmcheers,AJ
Commodity parts of amplifiers are just that. The only thing that matters is the electrical output at the terminals. Mind showing that lower distortion of triodes, full bandwidth into loads? TIA.cheers,AJ
Transistors are still inherently the highest distortion devices out there, with the possible exception of Nelson Pass's custom made SIT's. The old direct heated triodes (300B, 2A3, 845 etc), are still the lowest distortion amplifying devices extant.Transistors or tubes alone, don't make circuits.
The physics underlying all amplifying devices has not changed. Transistors are still inherently the highest distortion devices out there, with the possible exception of Nelson Pass's custom made SIT's. The old direct heated triodes (300B, 2A3, 845 etc), are still the lowest distortion amplifying devices extant.
No, that is not a problem with "Class A". That would be component or system architecture/design.No, that isn't a problem either, unless the speakers are chosen unwisely. The "20 watt" amplifier I linked would drive a HE (>98db/watt) speaker system, in room, to very high levels, where the ears own distortion would most likely start to mask moderate clipping (>113db peaks).cheers,AJ
(transistors) highest distortion devices???are you for real!!!
And it will still sond like crap unless you design it correctly:
well,depends on how you look at it...
you could still have good dynamic range but not as much as class-b...
have you ever built a class-a amp??
Yep. Check out this link:http://spectrum.ieee.org/consumer-electronics/audiovideo/the-cool-sound-of-tubesRead the sidebar links about jfets vs. 6AU6. Interesting.
As for TIM/Slew issues ...I have only seen real issues with low power/voltage output and limited high frequency response situations. Such instances invariably involved either tube amps or poorly designed, low power, SS gear. My opinion on NFB. Implementation of NFB should be done only after getting the basic design proper. And then, my preference is to use only small amounts, around every stage instead of globally and to assure that the phase is compensated well so that it doesn’t shift and induce positive feedback at very high f’s. One other thing. I see tons of discussion, indeed much marketing effort, emphasizing the importance of the types of spectra of the involved distortions while ignoring completely that if said distortions are below the threshold of hearing and, thus inaudible, then so what ….. you can’t hear them anyhow.
