Starting a CAPS v3 build
0 Members and 1 Guest are viewing this topic. Read 31376 times.
randytsuch
« on: 13 Dec 2013, 11:07 pm »
A few days ago I decided I wanted to build a CAPS v3, based on the Topanga version.
I may upgrade it in the future, but figured I would start with the low end model and work my way up as budget and time allow.
Made my first purchase today, bought a Samsung 840EVO 256GB SSD today from my local Frys.
http://www.frys.com/product/7796538?site=sa:adpages%20page:P7_FRI%20date:121313
I could have bought it cheaper from B&H, but I like to support local stores when possible, and also like instant gratification.
So far, that's how I am with this build  :D.
Next step is probably to buy Win 8, and then the MB and case and PS from Logic and I can start assembling.
Planning to put the music I usually listen to on the SSD, and will maybe hook up a sata hard drive to expand.  Decided against NAS for now.
Randy
randytsuch
Re: Starting a CAPS v3 build
« Reply #1 on: 17 Dec 2013, 08:15 pm »
So I’ve run into my normal problem, too much research   :D
After deciding to try a CAPS V3, I started looking at using Server 2012 as the OS running on a Xeon processor and MB.  This is more money, which would delay this project.
So I am currently considering using a Xeon compatible MB, but using a cheap Celeron process to save some money.  Could upgrade the processor later if I feel the need.
I also started looking at heatsink options.  I wanted to go passive, but am now leaning towards a low profile active heatsink, probably a Scythe one.  I should be able to lower the fan speed enough to make it silent.
Randy
dminches
« Reply #2 on: 17 Dec 2013, 08:44 pm »
What chassis/case are you planning on using?  Many of them do a very good job of cooling so that a fan-based cooler isn't needed.
randytsuch
« Reply #3 on: 17 Dec 2013, 09:12 pm »
So I could go fanless with something like this
http://www.quietpcusa.com/Streacom-FC8-EVO-Fanless-Home-Theater-Aluminum-Chassis-P1014.aspx
and I saw some Akasa cases that look nice, but I was wondering if they are too small.
I would like to be able to fit a couple SSD drives, or maybe one SSD drive and one CF card with an adapter.
I also plan to get the Paul Pang PCIE USB card at some point, so I need room for that too.
If I go active heatsinking, was just going to use the CAPS recommended case.
Randy
dminches
« Reply #4 on: 17 Dec 2013, 09:16 pm »
That will work with the Intel S1200 mobo.
This is what I will be building:
Xeon Music Server
Intel S1200KPR Server Motherboard - Socket H2 LGA-1155
Intel Xeon E3-1265LV2 2.50 GHz Processor - Socket H2 LGA-1155
2GB, 240-PIN Dimm, DDR3 PC3-85 - CT25672BA1067
Streacom FC8 Evo
PPA picoPSU 160 W
Paul Pang USB v2.0
Corsair Force Series GS CSSD-F128GBGS
Win Server 2012 R2
randytsuch
« Reply #5 on: 17 Dec 2013, 09:30 pm »
Xeon Music Server
Streacom FC8 Evo
PPA picoPSU 160 W
Paul Pang USB v2.0
Win Server 2012 R2
Thanks for the info.
I was planning to use the same MB.
Not sure about the RAM yet, I was looking at that.
I was wondering if people think the processor makes a difference in the sound?
I was looking at an inexpensive, low power Celeron figuring it would have enough hp to do what I need for this machine.
Rnady
dminches
« Reply #6 on: 17 Dec 2013, 09:42 pm »
I think Phil (and others) have said that the Xeon chip sounds better because of its extremely low latency.
randytsuch
« Reply #7 on: 17 Dec 2013, 09:52 pm »
OK, so maybe I do that later, but I don't have $300 for a Xeon right now.
And I guess they picked that Xeon because it has the lowest power consumption.
Randy
randytsuch
« Reply #8 on: 18 Dec 2013, 12:25 am »
So I just bought a "not perfect" Streacom FC8 evo chassis so I guess I'm going fanless.
Looks like a pretty nice solution, has heat pipes to conduct the heat from the processor to the chassis.
Two pieces down, many more to go
Randy
dminches
« Reply #9 on: 18 Dec 2013, 12:25 am »
Where did you get the case?
randytsuch
« Reply #10 on: 18 Dec 2013, 12:33 am »
http://shop.perfecthometheater.com/Streacom-specials-and-deals_c54.htm
But it looks like they just had one, its OOS now
Randy
Nick77
« Reply #11 on: 18 Dec 2013, 12:41 am »
Starting a build also, just going budget with Intel DN2800MTE board. Also have a PPA V2 card on the way. :)
randytsuch
« Reply #12 on: 18 Dec 2013, 01:19 am »
Which version are you building?
WGH
« Reply #13 on: 18 Dec 2013, 01:59 am »
What are you using for the 5V linear power supply? I picked up an Acopian 5EB200 for $20 shipped on eBay.
And don't forget about the PCI-E 1X Slot Riser Card Extender Flexible Extension Flex Ribbon Cable, none in my town so I had to order one.
There was a 90 degree cable in China for $9 but it is gone now.
Nick77
« Reply #14 on: 18 Dec 2013, 09:44 am »
I guess im building a variant of the Topanga or Lagoon with PPA USB card and M350 case.
WGH, thanks for the heads up. I will get one with the motherboard order. Plan to use RavPower battery charging cell with USB cable I bought from Paul. Hope I wont be searching for an Acopian.
randytsuch
« Reply #15 on: 18 Dec 2013, 02:05 pm »
For the PCI extension card, I would use the first one in the link below, if it doesn't interfere with anything in your PC.
A short board won't mess the PCIE signal up as much as the board with the longer cable.
http://www.logicsupply.com/components/riser-cards/pci-express-risers/
And for those interested, the PPA card is here
http://ppaproduct.blogspot.tw/2013/07/audio-grade-usb-30-pcie-card.html
His stuff appears to get good feedback, and seems to be good bang for the buck.
Randy
dminches
« Reply #16 on: 18 Dec 2013, 02:12 pm »
Randy, can't you also just use a ribbon cable?  That's what I did with my FC-10 build.  The bracket attaches to the case and the ribbon cable connects the card to the mobo.
shadowlight
« Reply #17 on: 18 Dec 2013, 03:29 pm »
Is it just me or is the PHT fanless chassis look the same as Streacom chassis?
http://shop.perfecthometheater.com/FLM-8-Black-Fan-Less-Mini-PC-HTPC-aluminum-chassis-FLM-8-Black.htm
dminches
« Reply #18 on: 18 Dec 2013, 03:40 pm »
I have asked them twice if it is just a rebranded Streacom case.  I haven't gotten a straight answer.
The specs and look are identical.
chip
« Reply #19 on: 18 Dec 2013, 07:59 pm »
Looks like this board is getting hard to find - Intel DN2800MT. What are options for something similiar?
