Starting a CAPS v3 build
0 Members and 1 Guest are viewing this topic. Read 31365 times.
TJHUB
Re: Starting a CAPS v3 build
« Reply #40 on: 20 Dec 2013, 01:21 am »
Yes, to date all my SSD 5V power supplies are a cut-off SATA power connector with red and black wires twisted to the red and black wires from a USB cable, and secured with electrical tape.  Some day I will get a cleaner cable (especially would love to find a FAT/THICK USB cable to do surgery on; one that has more than a couple strands of copper per cable to work with).
I think I've found the perfect cable.  I'll share when I'm ready.  It will require soldering/assembly though.  Maybe I'll make one for you...
ted_b
« Reply #41 on: 20 Dec 2013, 01:31 am »
You da man!! :D
TJHUB
« Reply #42 on: 20 Dec 2013, 01:34 am »
You da man!! :D
Nice of you to say...and you're probably right.  :D
dminches
« Reply #43 on: 20 Dec 2013, 03:13 am »
Here is the custom cable I made.  I started with a USB cable, cut off the end and attached a sata power molex.
ted_b
« Reply #44 on: 20 Dec 2013, 03:29 am »
Nice David.  Where is the splice?
dminches
ted_b
« Reply #46 on: 20 Dec 2013, 03:57 am »
Nice, so do you use some kind of punchdown tool which strips the wire too?  These would be great if the USB cable red and black wires were a bit larger than the strand of hair ones I used.
dminches
« Reply #47 on: 20 Dec 2013, 04:04 am »
The connector is self stripping.  When you put the wires in and put on the cap it strips the wire.
If you can find a USB cable with a thick wire it would work very well with this.
ted_b
« Reply #48 on: 20 Dec 2013, 04:39 am »
Thanks.  Ordered a few, then ordered a couple of these ( with awg 22 power wires)
http://www.newegg.com/Product/Product.aspx?Item=N82E16812189234
Bear
« Reply #49 on: 20 Dec 2013, 04:41 am »
randytsuch
« Reply #51 on: 20 Dec 2013, 05:49 am »
One more option for the usb cable side
http://www.allelectronics.com/make-a-store/item/USB-65/USB-5V-POWER-BREAK-OUT-CABLE/1.html
I would also like to thank all those who have posted, I have learned a lot already.
Randy
NickS
« Reply #53 on: 21 Dec 2013, 03:03 pm »
The FSP SMPS is a FSP brand model number 120-AAB switching power supply.  It is 19V, 6.32A feeding a 120-WI-25 wide input picoPSU.
Terry, how do you get 12V to the motherboard with this combination?  I don't see a 12V connector on the 120-WI-25 wide input picoPSU.
TJHUB
« Reply #54 on: 21 Dec 2013, 03:18 pm »
A 4 pin molex to 4 pin CPU power adapter.
randytsuch
« Reply #55 on: 21 Dec 2013, 05:11 pm »
Deleted, misunderstood a previous post
ted_b
« Reply #56 on: 21 Dec 2013, 05:19 pm »
I was looking at the DN2800MTM datasheet, it looks like it has the equivalent of a pico PS built in, and you just need to provide 12V to the jack on the rear connector.
Or are you asking about the S1200kpr motherboard?
Randy
Randy, yes he was asking about Terry's mobo.  Mine has the wide pico too (I replaced the standard one I bought at PHT with the wide one; I use an Asus P8H77-I mobo for my Zuma).  I was not as astute as Nick, so I had to wait until I later ordered the 12V 4 pin cpu connector/Molex adapter.
By the way, I tried the new FSP and both yesterday (cold, new) and today (plugged in for 24 hours) the thing spits  and sizzles with a background noise that sounds like morse code.  It's going back to Amazon.  I'm 0-for-2.   Hynes rules!
dminches
« Reply #57 on: 21 Dec 2013, 05:32 pm »
Ted, can you post a link to the molex adapter since it sounds like I will need that too. I have the S1200 on the way as well as the PPA wide pico.
NickS
« Reply #59 on: 21 Dec 2013, 05:39 pm »
Here is the one that I discovered following Terry's advice:  http://www.amazon.com/gp/product/B000BX4J9O/ref=ox_sc_sfl_title_4?ie=UTF8&psc=1&smid=A3VVSNFYKYYMUQ
Keep in mind that you will likely also require a Molex splitter if you don't already have one hanging around:  http://www.amazon.com/gp/product/B000067SCY/ref=ox_sc_sfl_title_3?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
