0 Members and 1 Guest are viewing this topic. Read 31411 times.
Randy, can't you also just use a ribbon cable? That's what I did with my FC-10 build. The bracket attaches to the case and the ribbon cable connects the card to the mobo.
Great comments - thanks. That should be a sticky!Can you tell me what a FSP SMPS is? Also, do you think that an iFi USB PS should work as well at the Anker E4?Finally, what do you use to connect the PPA USB card to the mobo or you you insert it directly in?David
I have never seen an impedance controlled cable.
I'm thinking about going this route as well. What's the ballpark figure we're looking at for a CAPS build?
I was considering using a MSata SSD for my build, I guess with the results im hearing about powering separately that would not be a good idea. ??
And of course this begs the question, how do you power your SSD separately? Make a diy cable?
