0 Members and 1 Guest are viewing this topic. Read 31367 times.
Im using the Atom based DN2800 and bought the USB to molex cable from PPA. Ill have to figure out best results with battery to SSD or USB card. Thanks...
I think $14
TedAnd the only reason I brought up the input voltage is that on the first page dminches said he has buying the PPA Pico, and since he was asking about it I wanted to clarify that point.Randy
Thanks Randy. This requires a lot of attention and reading.
Randy. The only reason we have been bandying about the FSP model is because that specific model was tested as a perfect mate with the specific pico we have been referencing. IOW, the understanding of mating a ps with a pico has been documented, and mentioned a couple times on this thread.Yes, Paul's pico might be a bit cleaner. I'm not sure what he's added (filtering,e tc) to the pico-box stock one.
Well there is a lot of great info here already. If its alright with Randy i will add a little real life experience. \
Hi Keith,Hard to tell from the pics, but will your HDD mount allow you to flip it over? The cables would be out of the way of the lid at that point although that may place the cables too close to the heat sync.Best,Ed
The connector is self stripping. When you put the wires in and put on the cap it strips the wire.If you can find a USB cable with a thick wire it would work very well with this.
Its been 15 yrs since i built a computer, i think i have this correct but if you can peek at this case power attachment wires??
