0 Members and 1 Guest are viewing this topic. Read 106728 times.
Why not get a Lampizator DSD only DAC, and then oversample all PCM music to DSD on the fly via HQplayer. If the Lampizator DSD ends up being really good, this approach will allow for a simpler DAC and conversion, with the tricky conversion (PCM-DSD) done in software by a powerful computer.Consider that Meitner/EMM and Playback Designs DACs both convert all PCM to DSD before conversion, and sound quite good in doing so, giving PCM some of the sonic advantages of DSD.
Well I just hooked up my new 4/4 Lampizator. Mine has a Tube rectifier, Jensen caps and USB. After 2 hours it is showing all kinds of special promise. Clear and inviting door into the music. I have not heard any digital front end sound quite this involving and musical.More to come......
Right under the IEC there is a small notch you can fit a screw driver in and pry. Here is an illustration:Double check your fuse value needed. The Level 4s say 1amp on the back as does my Big Six, but a buddy's Big Six says 1.25amp.
Well I went back to Grants to help tube roll in his Big 6. Wow, what a transformative experience, not too mention educational for me and my imminent 6. .....
1. Just ordered a matched pair of Philips SQ e88cc and tung sol 6x5 (on Lukasz recommendation).
