0 Members and 1 Guest are viewing this topic. Read 106801 times.
Does no one use hirez files with the Lampizator, hear any difference or is it so good at redwood hirez isn't warranted
BRM,Are you using USB? Pops occur with which program? If Audirvana+, does it happen when playinyback of a playlist in order or when skipping tracks randomly?I use a USB converter on my L4, no USB module and I never gets pops and clicks.I use a Lindemann DDC or an iFi iLink. (Both sound great and are integer mode capable on A+)
You have the Amanero chipset in yours? I get popping anc clicking with Foobar and JRiver both. Don't we lose fidelity with using a USB converter instead of straight USB??
Hi rez (not DSD) in my L4 is fantastic. If I can get a program to not pop and click between tracks that would be even better.
Problem solved. Now to listen more and give my feedback on this great dac.
How did you solve it?
