0 Members and 1 Guest are viewing this topic. Read 106731 times.
Jason, thanks! Pete, have you also tried no upsampling?
Just go to file types in jriver options menu and allow m3u (under playlists, after audio and images, etc)
My Lampi G4/L4 sounds incredible with iTunes, decibel, audirvana. Very happy. However, when I use audirvana and try to convert dsd to PCM the tracks load but when they play there is much static in the background. There is no static any other time. I don't upsample. Any thoughts? Thanks.
BRM, go to Tools,Options,File Types. Scroll down to Playlists,click on Audio Playlists,see (m3u,m3u8,pls,xpl,xspf). Under, Settings For File Types Selected Above , File Types: (m3u,m3u8,pls,xpl,xspf) check the box next to File Association:It should see your Squeezebox playlists and play them. In theory.Scotty
Hi Jason, Nice meeting you at Deepaks. Lukasz specifically asked me if you were happy, so glad to see the confirmation . As far as the static, I just copied and pasted him on this bc I'm curious myself.
No, purely push/pull tube amp. Rogue audio titan atlas magnum.
The bulk of my experience thus far has been with the 6X5 recti. For the guys with DACs that use the 5Y3 tube, what is preferred?I need some nice tubes for a Level 4.5 and I was curious about other offerings as well. I recall hearing good things about a NOS JAN tube, but don't recall which.
