0 Members and 1 Guest are viewing this topic. Read 41043 times.
My understanding is that this is true of the top 2 models in Grado's HO 'Reference' & LO 'Statement' lines. The top models in each of these lines is the 'Reference' (or 'Reference1') hence my cartridge is the 4mV 'Reference Reference1'. The top LO is the 'Statement Reference' (or 'Reference1'), which I think is 0.5mV.The next one down in both lines is called the 'Master' ... I was told that these are simply References which don't meet the high tolerance levels required of the 'Reference'.Regards,Andy
has everyone seen the Fremer article on the digital microscope?
But are they specifically looking at the stylus mounting angle when they differentiate between Master and Reference? Or are there other parameters that the manufacturer thinks are more important?I don't know either!Paul
The Master and Reference differ in several ways from the Sonata. According to Grado Labs the Master and Reference use a 5 piece cantilever vs 4 piece for the Sonata. The reference to the actual diamond seems to be the same diamond and shape of, between the Master and Sonata. The Reference is said to have a "True Ellipsoid". How the difference between "Special Grado Type" and "True Ellipsoid" affect the SRA is a big question. Not so sure Grado Labs will want to post "intellectual property", or even respond to the question of.
BTW, it turns out that I have the Sonata Reference 1 which I've learned is a Statement series model. And more "wholesome" is a word that applies.
No, the difference is the tip. The tolerance levels pertains to lesser models, which are all shown in pairs. If you check out Grado site, it clearly states in the last paragraph of the description, the diamond is a diff shape. http://gradolabs.com/page_cartridges.php?item=da592292ebe461e50bdddba88cff63f5You can see that Grado posted the specs for the Statement series for these, by mistake? I believe the Reference series all has HO, and the Statement series has LO. If you go to the Reference series Sonata and Platinum, the output is 5mV, Once again, the diff is the tip, nude vs bonded. Go down again to the Prestige series, also in pairs but virtually identical, except for tolerance. 5% of production run meet standards and become Gold, not Silver. On face value this appears to be BS. They sell more Gold than Silver, so how can 5% of them be Gold? I suspect the answer is in production runs, and not individual pairs. Unless they're in the dark ages, they make HO generators in batches. Tolerance probably pertains to DC resistance and inductance, being matched to specs and between channels. But there are differences between pairs with cantilevers, which are interchangeable. Exactly how tolerance fits in with Woodies, is unknown. All this is conjecture really, but is a plausible explanation IMO. Maybe the HO Woodies are the cream of the crop, being tested before cantilevers are fixed? I suggest a covert operation to find out exactly what's going on. We could have someone pose as a building inspector to gain access.....I think Clearaudio copied the Grado playbook with their MM line. All the generators have identical specs, output, resistance, and inductance. neo
Hi Marc,I was just going by the web site: "The Platinum model uses Grado's specially designed elliptical diamond mounted on a brass bushing, and the Sonata model uses Grado's specially designed nude elliptical diamond."I assumed that the Platinum uses the same tip as the Prestige series? Is there a difference in cut like .3 x .7 vs .2 x .7 ? I haven't been to Davey's site in awhile. I'll have to take a look, maybe he has some new carts since I last visited. David Dlaloum has an interesting site with a different variety of carts. I haven't been there for awhile either. https://sites.google.com/site/zevaudio/I think the best vocal rendition I've heard was with an old TLZ. I can't say exactly why, but there was definitely some magic. neo
