BRYSTON BDP-1/2 FREQUENTLY ASKED QUESTIONS THREAD
0 Members and 2 Guests are viewing this topic. Read 587509 times.
zoom25
Re: BRYSTON BDP-1/2 FREQUENTLY ASKED QUESTIONS THREAD
« Reply #1320 on: 8 Jan 2018, 03:49 pm »
I don't know what the other person meant. I was thinking from the BDP-1's display itself.
TJ-Sully
« Reply #1321 on: 8 Jan 2018, 11:09 pm »
thanks Chris. I see that drop down..with the option of playing Roon or MPD.
But, is it possible to switch between Roon and MPD without manually instructing the BDP to change modes?  So....one could listen to Roon...then play a track from MPD seamlessly?
I recall one time last year or so...i was able to do this. But maybe i was dreaming...? :scratch:
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #1322 on: 8 Jan 2018, 11:53 pm »
Hi
I will let Chris answer but because they are totally different operating systems  (MPD and RAAT) I do not think that is possible.  :scratch:
james
TJ-Sully
« Reply #1323 on: 9 Jan 2018, 12:03 am »
thanks JT
alexone
« Reply #1324 on: 23 Feb 2018, 07:33 pm »
...i updated my BDP-1 to the latest firmware. it now seems to take only 300 titles as a maximum. before i did the update i could easily load 1000 of songs in a playlist.
anyone any idea?
thanks,
al.
« Reply #1325 on: 23 Feb 2018, 07:35 pm »
anyone any idea?
thanks,
al.
Hi Al
There is a setting on the Dashboard where you type in the number of songs you want in a playlist.  Remember to reboot after you change the setting.
james
alexone
« Reply #1326 on: 23 Feb 2018, 07:41 pm »
...thanks, James. i knew that i was doing wrong something :thumb:
al.
alexone
« Reply #1327 on: 24 Feb 2018, 10:34 am »
hi, James or Chris or anyone who knows...
my BDP-1 plays absolutely nothing anymore?!? i just tried a few different usb sticks yesterday and the BDP stopped to accept them?! turned the unit on and off with no results.
no access via laptop or iphone7 as well.
helpless here...
al.
alexone
« Reply #1328 on: 25 Feb 2018, 06:43 pm »
helpless here...
al.
...anyone?
« Reply #1329 on: 25 Feb 2018, 08:17 pm »
...anyone?
Hi
Its a Chris question but try Factory Reset and see if that helps.
james
unincognito
    • bryston.com
« Reply #1330 on: 26 Feb 2018, 04:53 am »
helpless here...
al.
Does the front of the bdp show the BDP’s network interface as being offline?
http://support.bryston.com/downloads/BDP/Manic%20Moose%20Manual.pdf
alexone
« Reply #1331 on: 26 Feb 2018, 06:33 pm »
hi, Chris!
not really sure what you mean...but in either case - what should i do?
thanks,
al.
alexone
« Reply #1332 on: 26 Feb 2018, 07:30 pm »
...Chris, i disconnected the lan cable from the player. with good results as it started to play :D
but when i plugged the cable back in and tried to get access via iphone...it stopped again to play :scratch:
al.
unincognito
    • bryston.com
« Reply #1333 on: 26 Feb 2018, 08:07 pm »
hi, Chris!
thanks,
al.
Is the manual I linked above unclear?
alexone
« Reply #1334 on: 27 Feb 2018, 04:14 pm »
...maybe i should read it again.
alexone
« Reply #1335 on: 27 Feb 2018, 05:56 pm »
Chris,
the IP adress is gone :o
instead the display shows the following:
Bryston BDP-1
eth0 00:0d:b9:0d:d5:e8
still no access via iphone and/or laptop
« Reply #1336 on: 27 Feb 2018, 06:31 pm »
Chris,
Bryston BDP-1
Hi Al
It sounds like you are not connected to the network.   Will let Chris wade in.
james
unincognito
    • bryston.com
« Reply #1337 on: 27 Feb 2018, 08:21 pm »
Chris,
Bryston BDP-1
please push the down arrow button, it should either declare eth0 as offline or give you an ip address.
Chris
alexone
« Reply #1338 on: 28 Feb 2018, 05:56 pm »
you are correct, Chris. by pushing the arrow button down it says eth0 offline.
i should check the ethernet connection, right?? :icon_lol:
al.
unincognito
    • bryston.com
« Reply #1339 on: 28 Feb 2018, 06:12 pm »
Yes, there should be two lit LED's, one on either side of the Ethernet cable on the back of the BDP.
Chris
