BRYSTON BDP-1/2 FREQUENTLY ASKED QUESTIONS THREAD
mcochris
Re: BRYSTON BDP-1/2 FREQUENTLY ASKED QUESTIONS THREAD
« Reply #1660 on: 10 Mar 2024, 10:45 pm »
Thanks inglisd! I was able to SSH into my BDP-3 and poke around.
The directory where the music on my internally-mounted SSD is /media/Music. Fortunately, this directory is readable and writable by all, so we are good to move/add/copy files in and out.
If you insert a flash drive on one of the external ports it will show up as "/media/Samsung-USB" or something similar based on the flash drive manufacturer. I ran a USB3 extension cable from one of the rear USB3 ports to get easy access to USB3. The two ports on the front of the BDP-3 are only USB2 and too slow to transfer files.
If a user has some experience with the linux command line, moving files on/off the flash drive to the internal SSD is easy.
I backed up all the files on the internal SSD to another drive via rsync in case the internal drive goes bad or the BDP-3 stops working. I'll post more on that later.
Remember to unmount the flash drive via the MM system interface. We can't mount/unmount anything without root account access, and we don't know that (yet).
gil99
« Reply #1661 on: 10 Apr 2024, 02:33 am »
Hi all,
Will replace my Bdp-1 with a Bdp-3, is there a way to copy my playlist from the 1 to the Bdp-3. Thanks
Gilles
ETSUhoopsFan
« Reply #1662 on: 12 Jul 2024, 12:54 pm »
I have the BDP-1 and BDA-1 combo and was wondering if the BDP-1 can be used as a USB/SPDIF converter?  Maybe I am crazy but seems I read an article one time where someone was using it that way.  I ask because I want to to play Tidal via my PC rather than using the manic moose interface through the BDP-1.  I currently have my PC directly connected to the BDA's USB input, but of course this way it's limited to 44.1 and 48kHz data.  Is there a way to send the signal from the PC's USB to the BDP-1 and then to the BDA (by coax or AES) to utilize the resolution support up to 192k on the BDA-1?  Or will I just need to look into an a separate DAC/SPDIF converter?  Thanks!
R. Daneel
« Reply #1663 on: 16 Aug 2024, 11:50 am »
Hi!
I do not think that is possible. With custom software for the BDP-1, perhaps, but it is questionable how reliable it would be or if it would even work.
The most elegant way to go around ait is to use a USB-S/PDIF convertor like you suggested.
Though not asynchronous, the USB interface on the BDA-1 is rather good so don't  expect major improvements, especially with streaming services.
Cheers - Antun
Robbob
« Reply #1664 on: 20 Oct 2024, 10:24 pm »
Hi and thanks to James and Chris.
Thanks for setting up this Thread.
A good place for legacy product users to share information.   The bryston gear just keeps on going and going doing what it should and given that ... this forum is a good place for users to share experiences.
Rob
cmccaul
« Reply #1665 on: 11 Nov 2024, 01:44 pm »
I have a BDP-3 and I'm trying to compare USB and SPDIF output to my Benchmark DAC3.  I have both devices enabled as shown below, but I can only get sound from the SPDIF connection if I unplug the USB cable and enable SPDIF only.  I've tried powering down both units, unplugging the BDP-3, but no luck.  Is it possible to get output from both the USB and SPDIF at the same time?
Or, does anyone have strong opinions for USB vs SPDIF?  Thanks for any help!
Stefan_DR3
« Reply #1666 on: 11 Nov 2024, 02:32 pm »
Works on mine with the same settings, as long as you’re playing a rate compatible with spdif. I tested with a regular 44k file.
cmccaul
« Reply #1667 on: 11 Nov 2024, 02:55 pm »
I'm trying to play a compatible file.  SPDIF plays fine with the USB detached up to 192kHz on the Benchmark DAC.  Could it matter which BDP-3 USB port I use?
JfTM
« Reply #1668 on: 31 Dec 2024, 02:44 am »
Hi Folks - a place to ask and answer more technical and operational based questions on the BDP-1 Digital Player
james
Back to the dongle question.
I have a BDP-1, replaced by a BR20, that I would like to move to another system. That is inaccessible for wired Ethernet.
There are now many WIFI to Ethernet adapters.
Will they work with a BDP-1?
inglisd
« Reply #1669 on: 31 Dec 2024, 01:34 pm »
any wifi extender with an ethernet port that you then wire to the BDP should work
as long as your main router and the extender can establish a good wireless connection.
Buy one on amazon and if it doesn't work return it.
Partroysound
« Reply #1670 on: 16 Feb 2025, 06:10 pm »
Heed help. I have 2 BDP-1 units. One works fine with either of my 2 hard drives. The other used to work the same but now it only partially loads and then won’t continue. When I go into the connected drives section and hit update it says: cannot create file directory. USB thumb drives seem to work.
Thank you
Marc
Jozsef
« Reply #1671 on: 4 Apr 2025, 01:29 pm »
Thank you
Marc
I would email Adam Tanner, [email protected]
I'm sure he will take care of you.
Ekimnodyl
« Reply #1672 on: 9 Aug 2025, 10:01 am »
Hi
I've got the following error code coming up on my BDP-2
I've looked at the BDP error codes in the support paged and, insofar as I am able, have to follow the possible fixes. I don't have a Bryston DAC so am unable to test whether the DAC is receiving a lock (apologies if I am mangling the correct technical terms). That leaves reimaging the sd card.
I've tried the following links for getting hold of an image but they don't seem to exist
https://dl.dropboxusercontent.com/u/86196657/DOCS/BDP%20image%20Mac%20OS%20X.pdf
https://dl.dropboxusercontent.com/u/86196657/DOCS/BDP%20image%20Windows.pdf
Any ideas what I can do next?
Mike
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #1673 on: 9 Aug 2025, 11:39 am »
Hi Mike - please email Adam - [email protected]
Ekimnodyl
« Reply #1674 on: 9 Aug 2025, 12:27 pm »
Thanks - will do
canuck5
« Reply #1675 on: 9 Aug 2025, 06:55 pm »
try changing the battery, I had the same error, switching out the battery solved the problem.
Stefan_DR3
« Reply #1676 on: 9 Aug 2025, 08:23 pm »
If that doesn't work there are some useful links here including the x86 download:
https://support.bryston.com/downloads/BDP/Manic%20Moose%20Sources%20R4.pdf
Ekimnodyl
« Reply #1677 on: 10 Aug 2025, 01:30 am »
Thanks to all of you for your advice. It's very much appreciated. Also the speed of James' and Adam's replies. Awesome community.
One suggestion I found elsewhere (ChatGPT) was to unplug the BDP-2 and leave it off for several hours. As I was about to head off for the night I thought I'd give it a try - nothing to lose. It worked. No idea why - however, I'll take it as a win.
Best
Mike
lenticularis
« Reply #1678 on: 11 Sep 2025, 06:17 am »
I am also getting the dreaded Error 09 message over the past two days. I bought my BDP-2 locally here in Australia only 11 days ago (delivery date).
I am loathe to attempt to claim a refund I would rather get this working again. After struggling with two stubborn case screws I was able to inspect it this afternoon. I have replaced the button battery and also tried booting with and without the tiny 240GB SSD discovered inside, all to no avail.
I don't know if this is a direct outcome of the Error 09 status however the unit is no longer recognised as a device on my network, either using bryston-BDP-2.local or the actual IP address.
The Dropbox links in the error code PDF file are dead so I do not know what the reflash procedure is for the CF card, otherwise I am capable of doing a re-flash.
« Last Edit: 11 Sep 2025, 12:46 pm by lenticularis »
lenticularis
« Reply #1679 on: 11 Sep 2025, 06:48 am »
...having tried booting with and without the SSD being connected at the SSD end of the cable, I tried the opposite end of the cable after seeing this option described in an old review
(https://www.stereophile.com/content/bryston-bdp-1-digital-audio-player-bryston-bdp-2).
After adopting that method the unit booted successfully, so for now I have left the cable unconnected from the motherboard. I am using the BDP-2 as a Roon endpoint in any case and I have a NAS library of FLACs.
Here are the internals of my unit.
« Last Edit: 11 Sep 2025, 12:47 pm by lenticularis »
