0 Members and 1 Guest are viewing this topic. Read 45800 times.
Outstanding, ebag4! Looking forward to watching this as well.Say, Ed, could we have a close up of the Sappele? Kinda hard to see in the "group" photo.
Ed,From the pictures of your speakers and the close-ups of the veneer, your amplifier should be stunning. I'm looking forward to seeing your project progress!Best Regards,TerryO
2a3 amp you're talking 2.5 watts max. And awesomeness levels of close to 5,363.24 by my calculations.
Stereomour is our latest high quality single ended, parallel feed, directly heated triode amplifier kit, a stereo integrated amp with three inputs that can be configured as a 3.5 watt per channel parafeed SE 2A3 stereo amp or 1.75 watt per channel parafeed SE 45 stereo amp (with user supplied tubes). Parts are supplied to allow creation of either circuit, with the 2A3 tubes included in the kit.
... And awesomeness levels of close to 5,363.24 by my calculations.
What speakers would be a good match with this amp? Suggestions, please... thanks!
Somewhere when its done Ed and you take the finished shot can you list some specs with it, watts, etc... Thanks.After reading your quote about which end of the iron gets hot- which I learned early by burning myself but good when I was pee wee- I'm now interested to see if I could maybe pull this off...
