Bryston Owner's Speakers
0 Members and 1 Guest are viewing this topic. Read 68975 times.
vegasdave
Re: Bryston Owner's Speakers
« Reply #160 on: 6 Apr 2011, 08:00 pm »
alexone
« Reply #161 on: 6 Apr 2011, 09:21 pm »
Larevoj,
i had the Sonus Faber Cremona (full range) speakers for a while. i really enjoyed the mids and the bass but found out that the tweeter was somewhat "too much" for my ears...
so how is the tweeter's sound now? do you hear any harshness??
thanks,
al.
larevoj
« Reply #162 on: 7 Apr 2011, 01:27 am »
Hi Alexone,
I had no issue at all and in fact it was much more refine than the Dynaudio Focus 110. There were a number of tracks I used to skip due to harshness at moderate listening levels but now I no longer have this issue. It It doesn't harden up and is not in our face...I love every note from it  :)
Viajero5000
« Reply #163 on: 13 May 2011, 07:12 pm »
For anyone looking for a high quality full range speaker for (relatively) little money on the used market to match their Bryston gear, the Infinity Prelude MTS are a pair of speakers I have enjoyed using from time to time with my Bryston equipment.  In conjunction with Bryston downstream equipment, they are uncoloured but sound lively and engaging, and are a full range speaker with a small footprint.  They were quite expensive new, but thanks to the Infinity brand name most audiophiles have ignored them and they are consequently a bargain used.  Just be aware of problematic drivers.  Info and a review below:
http://www.stereophile.com/floorloudspeakers/295/index.html
swm_uk
« Reply #164 on: 16 May 2011, 01:00 pm »
currently running PMC AML1's. must get the cable routed under the floor and room redecorated  :roll:
AML1's.
dogbait
« Reply #165 on: 16 May 2011, 01:32 pm »
All KEF. Reference 4-2 fronts, Reference 200C center, Reference 2 rears:
Need one more monoblock... :lol:
Stu Pitt
« Reply #166 on: 17 May 2011, 02:12 am »
Only one?  :green:
vegasdave
« Reply #167 on: 17 May 2011, 10:03 am »
Those are ST amps, true?
Fernando
  • fernando _at_ -34.899705, -56.158880
« Reply #168 on: 17 May 2011, 12:59 pm »
I bet so. What puzzles me is that where the ST Series logo should be, I read something like PMC, but not clearly enough.
vegasdave
« Reply #169 on: 18 May 2011, 12:21 am »
I believe it does say PMC. I heard the PMC modifies the Bryston amps?
HsvHeelFan
« Reply #170 on: 18 May 2011, 04:28 am »
My speakers are 1995 vintage KEF Q-70's.
I've got a big Velodyne sub handling everything below 80 hz.  I listen to a lot of large orchestra classical, Jazz and Classic rock.
My local audio guy told me for years that I didn't need a sub-woofer.  Even with a nice set of KEF's, a sub-woofer makes a big difference.
HsvHeelfan
dogbait
« Reply #171 on: 18 May 2011, 11:20 am »
Yessir.
PMC is the UK distributor and an excellent speaker manufacturer in their own right. The guy I bought them from had them hooked up to a pair of MB2-XBD speakers (he's using 28B SST amps now). I assume he bought the 7B ST with his speakers from PMC directly hence the branding:
I haven't heard of PMC making any modifications to the amps, sure James can chip in and let us know if they do?
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #172 on: 18 May 2011, 11:33 am »
PMC remove the clipping circuits on the Active systems from the amps because the clipping circuits are built into the Electronic Crossover.
james
« Reply #173 on: 18 May 2011, 02:04 pm »
james
vegasdave
« Reply #174 on: 18 May 2011, 08:47 pm »
James! Your system makes mine look like a toy! Which speakers are those?  8)
vegasdave
« Reply #175 on: 18 May 2011, 08:47 pm »
james
Ok, cool. I'll make a note of it.
vegasdave
« Reply #176 on: 18 May 2011, 08:48 pm »
Yessir.
Cool, man. Thanks for the info!
Phil A
« Reply #177 on: 18 May 2011, 08:52 pm »
The speakers in James' picture before your post are Thiel MCS1s.  I use an MCS1 as a center channel with my 3.7s
vegasdave
« Reply #178 on: 18 May 2011, 08:57 pm »
Ok, cool. Thanks.
Phil A
« Reply #179 on: 18 May 2011, 09:07 pm »
You can get them with stands for positioning as a center channel (sideways) or main channels as in James' picture.  I have mine on a shelf with the grill.
