0 Members and 1 Guest are viewing this topic. Read 116207 times.
Here are several pictures of the Lores in my rearranged room. My iniital postings showed the Lores occupying the same location as my Horns. I didnt like the catecorner arrangment, but the Horns sounded better in that location then on the long solid wall or corners. The rear horn mouth prevented the Horns from sounding good in the corners adjacent to the glass sliding doors (a sonic nightmare!) However, despite the twin sliding glass patio doors as the front wall the Lores, on the other hand, sound outstanding in that location. Definately benefit from front ports. The are positioned about about 15' apart and 24"-25" from the corners with toe-in, and resting with spikes on spare pieces of 3/4 inch thick solid oak flooring strips (finished side down to protect from the spike marks just in case I need to use the strips in the furture!) The bass is stupendous...deep, detailed, and natural sounding. The soundstage is wide, particularly with the spacing, with good depth that becomes very deep when I pull the speakers out another foot or so into the room. Everythings else (highs, tone, dynamics etc.) remains the same: excellent!
Bass is foundational (not optional) IMO. This willingness to do without is my biggest gripe with single driver fans. So many delude themselves into believing it doesn't exist or isn't important. I know it can be expensive to obtain (correctly) but an $800 sub can do wonders.
Genjamon,Here's a little background. I've had the Horn/Vaughn Audio Carina SET amp combo for nearly 3 years, to include use of the Cube for a while (sold it for other things!). The Cube added low end, but seemed to do something I didnt like (integration) that, in my room and to my taste, seemed to detract from the Horn's strenghts. For comparison, the Klipsch Forte I's had outstanding integrated bass and dynamics, but couldnt match the realness factor in the mids that the Horns projected (although it comes close with cap upgrades/replacement). The Carina/Horn combo was wonderful, but I really needed bass, and developed a feeling I needed a little more dynamics and extension as well. Ed at the Hornshoppe always talked about playing his with lots of power, so I looked at more powerful, affordable options. While checking the Horn forum, as well the the Omega Speakers forum, I found a number of people who use the Ampino with single drivers. I contacted the distributor who was out of Ampinos, but had a demo Ecstasy IIb at a great price! I purchased and evaluated it with the Horns. Lots of extension, but seemed a bit brighter and less 3D. Tubes versus SS I suppose, and overall synergy. The decision was made to get a larger speaker since I felt there was no substitute in my case for size. Hence the Lore. Initial listening with the Carina sounded good, but nothing earthshattering, I proceeded to do some initial break-in of the Lores with the Dayens, then settled down to listen. What I heard is what I described earlier! Thinking it could get better I switched in the Carina, but couldnt completely re-create the sound of the Dayens/Lore combo. Back and forth listening showed the Carina to be smoother, but overall I liked the Dayens. This is coming from 15 years of tubes! But I have to stress it really is a synergy issue, not the individual components (at least in my case). I suspect a 5-10 watt Carina SET (as opposed to 1.5) would recreate the same thing...but there is no such Carina! There are little tradeoffs in anything, but this current combo accomplishes what I wanted, while keeping the essence of tubes, with improvements in some areas . Now, the Ecstasy II is 70 watts versus your 25. I dont know how much a difference that would make between the two models paired with the Lore, but I can say the Ecstasy works in my system in replacing an outstanding SET amp.
check out my post in this thread for info on how to tweak the Lores for much improved sound....real cheap.http://www.audiocircle.com/index.php?topic=94833.0
JLM - I'm not sure this applies for 8" or 10" single drivers, especially in a small room. I have both 8" and 10" in a 12' x 13' room, and bass is not lacking at all.Just FYI
