0 Members and 1 Guest are viewing this topic. Read 115641 times.
No papers here, they is what they is. In regard to bass, I currently have my Lore near the corners of my living room, about a foot from the back wall and a foot from the side. Bass is good, lively and not boomy, at my center room listening position. I previously had a 10" sub in the room and, yes, it could generate some more db at lower frequencies. But it was much harder to get a nice tight bass out of, mostly due to room placement.That woofer is now in my tv room, with another of the same, serving as stands for Madisound BK 16 horns. I have yet to play with the adjustment of this mess, yet, but I may have created a monster. The supertweeters are now above ear level and the Fostex are dead level. I played some Suzanne Vega when wiring this up and it seemed that this system was much improved. And I think it is because the subs are now in the same plane as the speakers and in phase. So, I may have gotten two improved systems with one Lore purchase. YMMV.
Did any Lore owners get any paperwork from Tekton when you received your speakers ?I don't recall getting anything --- little strange not even one sheet of paper describing the speakers or their specs .......they do sound great tho !zeke
I'm not trying to say anything about the sound of the Lore, other than it looks like it might be a very nice high efficiency design. I'm not sure exactly what the criteria is to qualify as a full range speaker, but this is a 2-way. The woofer has response to 4K, but it's probably crossed at 2K. I don't object to the discussion or anything like that. I just thought I'd point that out.neo
I've found that the "fullness" comes from the size of the primary driver, so not surprising that the OB45 sounds "thinner" than the Lore/Mini-Lore.
