0 Members and 1 Guest are viewing this topic. Read 60273 times.
Does the RCA out connect to a hard soldered point on one of the PCB's?Is it (at least originally) a single piece through to the headshell mount?Trying to work out whether this is a job for me, or one to take in to a workshop....
I took a close look at the feet as well - the rubber is starting to show hints of cracking - I treated it with Rubber Renew.... but I think I need to look for alternate feet....Does anyone know what the spec for the thread on the feet is? (or how to measure it?)The original setup with the bell shaped vibration absorbing rubber is pretty standard - various versions of it are available made of rubber, sorbothane, and other elastomers (from various vendors). But they don't have the appropriate chrome/metal look...I also took several spare sorbothane pads I had lying around - enough height for them to make solid contact with the center of the plywood underpannel (and get slightly compressed).... that should dampen the wobble board a bit.Has anyone made a new Plinth for one of these?... It doesn't look all that difficult, just requires a lot of accurate measurement.... and then precise cutting..
