0 Members and 1 Guest are viewing this topic. Read 60282 times.
A comment on www.stevehoffman.tv that a Michell clamp would help tighten up the bass. I like that it is quite lightweight. Costwise i think it would be about the same as the 'clay/putty'. Of course results may vary, so has anyone tried this ?
You can make your own pretty effective cheap silicone feet by buying dimpled silicone coasters for glasses and pots at a kitchen store. A big pot holder may cost $9.99 (US, Cdn or Aussie) and you can cut into much smaller pieces to make your own feet. Making 1" squares and stacking 3 on top of one another (the dimples hold the stack steady) make great feet.Maybe I will take a pic of it to show everyone very cheap yet effective DIY silicone feet.The range of colors is nice, too.
The steps:1. Fill your QL-Y5F with clay (maybe you already did?). This step, in itself, seems to make feedback WORSE...so you have to do steps #2 and #3 to get your deck back into playing shape again 2. Spray the flexy mdb bottomboard with viscoelastic damping compound outside and in (this is the major culprit for the feedback your experiencing). That flexy bottom is creating something of a speaker cone, amplifying the feedback back into your deck and music. 3. Sit your deck ultimately on 4 squishy (ie, compliant) feet. While I much prefer hard feet on every other table tried, on the mdf'ed JVC's hard feet again amplify the feedback issue. If you don't have squishy feet about (you probably do as you are experienced), just keep the stock rubber feet on until you find something better. As bad as those stock feet are, the rubber does a so-so job of keeping feedback levels lower on these decks. I use Herbies Tenderfeet sitting atop brass feet, but are equally pleased with a combination of Vibrapod/Vibracone - 4 each to a table in each corner. John
