0 Members and 1 Guest are viewing this topic. Read 60278 times.
Ignore the manual and use a test record to adjust it. After that - use your ears.bye for nowDavid
I don't remember what cartridge you are using - but the definitive recommendation for something really good for a little more than USD$100 is the Denon DL-110 (at $139 list)
How about what's UNDER your JVC? I've found what's under your deck is in almost all ways a better upgrade than a cartridge.
Once I found maple cutting blocks, at least 3" thick and wide and long enough to sit under my decks, I was smitten forever. If you're using rubber bushes only between your deck and a shelf of some sort....buying a nice slab of maple cutting board for ~ $100 might make the most beneficial upgrade of all. This is the one I have: http://cgi.ebay.com/MICHIGAN-MAPLE-BLOCK-CUTTING-BOARD-BUTCHER-BLOCK-A-/110678127928?pt=LH_DefaultDomain_0&hash=item19c4ee3538
You really outta' stuff the clay inside, too, at this point. ....the clay inside really gives some sturdiness, weight and authority to the sound of your deck. Using 5 rubber bushes as you have, buying a 3" cutting block and having sprayed the bottom board 2x....I think you're well on your way to getting your JVC to perform at an optimal level now. Go the whole hog and plasticlay the innards. You'll be glad you did at this point.
Been wanting to try a 680 with Jico Shibata (havn't heard a 680 in many years - had one in the late 80's)The Ortofon Concorde is good and bad in parts...If you have the original "HiFi" early versions weighing in at 6g - they will not balance on the QL-Y5F without a lighter Counterweight.... first problemSecond problem - some of them have adjustable overhang and some don't - the light early HiFi models I had didn't have adjustable overhang, and their overhang was set for Technics SL - which is wrong for the JVC.... so I got rid of them to new homes around Aus.If yours is one of the heavier versions with the adjustable overhang - these problems will not exist!
I fitted my Digitrac 300SE stylus to a 1/2" mount OMB cartridge - with the additional 2.5g weight removed... The combination required that I use a lighter weight CW to balance it - but resulted in better sound. (High compliance cartridge/stylus prefers lower mass arm....)
Don't forget to cut off the little tab on the stylus to allow it to mount properly on an OM engine!
I also checked the Digitrac 300SE under a microscope at 200x - it appears identical to the OM30 in every way.... (and it definitely sounds better than the OM20 I have).
This table when properly fettled should be good right up into the couple of grand range cartridges I would have thought.... After all in today's dollars this is a $3000-$5000 turntable.... (which opens up a whole other discussion I know!)
There are plenty of good solid native Aussie hardwoods you could use.... you could also try Panzerholz -
- Officeworks is one of the cheapest suppliers of Plasticine - so you can easily pick it up in most major areas around Aus. (don't know where you are...)
yes so the usual rule of thumb for new gear has always been to double the full retail price as an estimate of local price - and then inflate appropriately to account for exchange rate - so 3x US street price is not at all unusual.About 3 years back I bought a set of Gallo Ref3.2's - local price AU$6500 - US Price US$2500 - see what I mean?
My question is:What difference would rewiring the tonearm make?Is it worth doing?Has anyone actually rewired one of these servo arms?More questions come to mind - but this is a good starting point
While I am here in JVC Land,does anyone use a peripheral ring clamp with their JVC?The concept appeals to me - mass in the right place (outside edge of platter) keeping the record pressed down, cleaning up the sound, also putting more mass pressing down on the top of the plinth... seems like this would work well.But there there is space for the ring - is there enough room - the platter is quite embedded in the motor molding....anyone have any experience with some of these? (on a JVC QL-Y ?)thanksDavid
