0 Members and 1 Guest are viewing this topic. Read 446042 times.
Congrats Evan,You sure have your listening 'work' cut-out for you.... I'm so enamoured with the FR-6SE that I rushed in to secure a spare for myself in case something untoward occurs.... Just to be safe....Regards
Straight off....if it sounds good, that's a great sign Evan.In the TransFi arm you have no worries about geometry but is there a way to check azimuth because you know a Shibata stylus is probably the fussiest profile for alignment.
Henry,I have the Feickert Adjust+ record and software. Dialing in the TK7, Kleos, and Zero on the Pioneer are on my list of things for this weekend.Oh, and I have a V15-III and Jico Neo-SAS coming! Did I mention I'm diving into the rabbit hole?Eav
Hahaha.....It's like you've been bitten Evan.... With all those cartridges, it might be a better idea to have them mounted in their own headshells and use them with the pivoted arm leaving the Kleos for the TransFi?Just a thought.....
The FR6e arrived today. Will mount it up on the Pioneer arm this weekend and give it a listen.
Yesterday, I just changed the Yamamoto HS3 boxwood to Yamamoto HS4 carbon fiber and everything else stayed the same. The P77 now sounds much more open & refined, less bloated, and in general much closer to the AC03, though the latter is still a notch more refined & open. On the downside, some of the warmth also disappeared. So I'm wondering if a headshell of hard wood like ebony or an ebony spacer with the carbon fiber headshell would be the optimal combination. What's your set-up for your Garrott P77?
Also, you've been advocating the Shure V15-III recently. Why the III rather than IV or V or Vx?
So which cartridges do NOT sound great on the HS4?? And what works for them?
You did mean the 6SE....?
Good question.... I've not heard the others and the III seems to have the greater reputation. There also appeared to be greater satisfaction with the SAS mating with the III than the others
Most of the cartridges I've tried sound better in the HS4 headshell and those that don't (like the Atlas)...at least don't sound worse
So for which ones do you prefer a wooden, metal, or ceramic headshell?
