Did you have/had an L-1000 ? I know it has the coils attached near the tip, but seems very different from the ART1000. The Victor has .22mV and 25 ohms ? The AT is coreless with .2mV and 3 ohm impedance. The Victor specs look more like a Denon and the AT looks like a hot rod 50ANV. It must have some powerful magnets.
Halcro,Do you know the differences between the "regular" neo SAS and the more expensive ones?Ruby and sapphire have the same chemical composition except for trace elements which determine color. Is one tapered and the other not? neo
Neo,The more expensive ruby stylus is tapered. No idea why they use ruby for the taper and sapphire for the straight cantilever.AC
I think ruby/CL is still $250, but that makes the regular SAS look like a deal.
With the improvement in sound that the original SAS rendered......you're damn right
