Speaker Cable Recommendations
0 Members and 1 Guest are viewing this topic. Read 57278 times.
dspgolf
« on: 8 Jul 2010, 07:03 pm »
Hi all,
Was looking for some advise pertaining to speakers cables(Bi Wire). Here is the system.
4b SST2
BP 26P
B&W 803D Loudspeakers
Sony XA 5400 ES sa-cd player
Would love to hear some input as to what others are using currently.
Dave    :?
vegasdave
Re: Speaker Cable Recommendations
« Reply #1 on: 8 Jul 2010, 07:16 pm »
I use Belden 10 gauge which I purcashed from Blue Jeans Cable up in the Pacific Northwest.
The Bryston cables are awesome too. Those are 9 gauge, I believe.
drummermitchell
« Reply #2 on: 8 Jul 2010, 07:40 pm »
I use to use Cardas GRC's,then switched to Bryston .
The Cardas seemed a little laid back,where the Bryston,basically said WTF,TIME TO PARTY
The Bryston seem alot more lively if that's what you like,LIVE compared to say studio.
Maybe when I hit 60,I'll go back to laid back :o.
Stu Pitt
« Reply #3 on: 8 Jul 2010, 07:42 pm »
I use Canare 4S11 from Blue Jeans Cable due to long cable runs that I have to live with.  No complaints at all about the cables or sound quality.  I dressed then up with Techflex and made them look all nice and expensive.
Napalm
« Reply #4 on: 8 Jul 2010, 07:49 pm »
KnowTalent
  • ...stuck in the middle with you
« Reply #5 on: 8 Jul 2010, 07:50 pm »
I second this recommendation!  you might first take a trip to your local Home Depot/Lowes and see what they have in 10 ga as you might be able to get it cheaper than BJC.
If you want something more snazzy I'd recommend either Analysis Plus Oval 9 or DH Labs Q-10 as both have excellent spade terminations and are not too overpriced given other offerings in the "boutique" cable market.
Napalm
« Reply #6 on: 8 Jul 2010, 07:55 pm »
Iyou might first take a trip to your local Home Depot/Lowes and see what they have in 10 ga
ROMEX  :lol:
95Dyna
« Reply #7 on: 8 Jul 2010, 07:56 pm »
WireWorld Silver Eclipse 6 connecting 7B SST2's to the Infinity 9 Kappas.  Bryston has used WireWorld cables in their show setups frequently according to designer and president David Salz.  I'm getting great results with mine.
http://www.wireworldcable.com/products/82.html
vegasdave
« Reply #8 on: 8 Jul 2010, 08:01 pm »
Well, he's gotta get the Belden or Canare. Anything less is a compromise, imo.
china
« Reply #9 on: 8 Jul 2010, 08:09 pm »
Hello,
  You might want to try Frank at Signal Cable.......very good customer service and they come with a thirty day return and lifetime warranty.
  Or just go to AudiogoN and wade through what is offered.
As always, all the best.
Ralph
95Dyna
« Reply #10 on: 8 Jul 2010, 08:12 pm »
I've seen this description "boutique" cable used frequently on this and other forums.  What exactly does this mean?  Does it have a definition?  :scratch:
VOLKS
« Reply #11 on: 8 Jul 2010, 09:35 pm »
I have heard the Acoustic Zen Absolute Shotgun speaker cables with complete Bryston system and i liked them so much ....i ordered them.Fast/detailed/and amazing bass
...however they are not cheap.
http://www.acousticzen.com/Speaker_Cables.html
Wind Chaser
« Reply #12 on: 8 Jul 2010, 09:43 pm »
Reality cables!  The latest reports on Nagy's cables look very promising.  Outside of that, there isn't anything I'd be too interested in.  After all, a short list should be short.
Laundrew
« Reply #13 on: 9 Jul 2010, 02:07 am »
Argentum Acoustics Aureus-2BW with supplied banana plugs.
Be well...
robb
« Reply #14 on: 9 Jul 2010, 03:36 am »
Hi--I have the 4bsst2  and Thiel 2.4 wired with Nordost cable. Awesome dynamics and percussion
RPM123
« Reply #15 on: 9 Jul 2010, 03:54 am »
Hi all,
4b SST2
BP 26P
dave    :?
[/quote
Check out the Clear Day Double Shotguns... reasonably priced, either a 30 or 45 day trial, plus Paul is a great guy!
1ZIP
« Reply #16 on: 9 Jul 2010, 04:30 am »
Napalm
« Reply #17 on: 9 Jul 2010, 01:45 pm »
Werd these for you:
http://gizmodo.com/302478/7250-speaker-cables-turn-you-into-a-dancin-fool
Tested and approved by Mr. Fremer.
Nap.   :lol:
Wig
« Reply #18 on: 9 Jul 2010, 02:31 pm »
 You can demo the JPS Superconductor 3 from the Cable Company. They blew away all of the cables I tried. My Avalons have never sounded so good!
 Wig
ian.ameline
« Reply #19 on: 9 Jul 2010, 03:28 pm »
