Maple Platforms and Amp Stands
0 Members and 1 Guest are viewing this topic. Read 97263 times.
solidwood
    • http://www.timbernation.com/MaplePlatform_PopUp.cfm
« on: 14 Feb 2004, 11:37 pm »
<html>
<head>Maple Platform Company --- Timbernation</head>
I make Maple Platforms and Amp Stands and anything Special you would like. Feel free to ask Questions
http://www.timbernation.com/MaplePlatform_PopUp.cfm" target="_blank">www.timbernation.com/MaplePlatform_PopUp.cfm
Thanks Chris Futrick Owner
</html>
[/b]
byteme
« Reply #1 on: 14 Feb 2004, 11:44 pm »
Chris is a stand up guy who in my experience does great work.  You can check it out here - http://www.audiocircle.com/index.php?action=gallery;area=browse;album=152
Fast, fair and quality, what more can you ask for?
DARTH AUDIO
« Reply #2 on: 15 Feb 2004, 12:55 am »
I use Chris's (Timbernation) platform under my Spectron Musician III amp. The craftmanship is "Excellent". Great workmanship at VERY fair prices. Check out his platforms, you won't be sorry.
JoshK
« Reply #3 on: 15 Feb 2004, 03:00 am »
I have 6 Maple platforms I order from Chris.  Excellent workmanship, great product at a great price.  Did huge wonders to my system.  Ask Daniel or Michael (mcrespo) about the improvements the maple platforms made to my system.
JoshK
« Reply #4 on: 17 Feb 2004, 05:25 pm »
beyond just the platforms take a look at this:
amp stands & misc
sjd
« Reply #5 on: 18 Feb 2004, 05:44 am »
Welcome Chris.  I am going to order some platforms from you soon.  Meantime, I have a product suggestion for you:
Did you ever think about drilling some of your larger platforms for those large threaded rods (I have some that are I think 5/8" and around 36" tall).  Sell them in batches of 3-4 finished, ship them flat, and we go to home depot or something and buy the rods.  One could spray paint the rods in a flat black (or leave them plain), and have a very sweet looking, solid, and reasonably priced stereo rack.  :)
  • Speakers....What Speakers ?
« Reply #6 on: 18 Feb 2004, 05:55 am »
Quote from: sjd
Yes, a flexi rack...good idea ! :)   http://www.montac.com/ht/flexi/  ... http://home.adelphia.net/~dbcraw/rack/
JoshK
« Reply #7 on: 18 Feb 2004, 02:03 pm »
Chris has something better than a flexy rack (and more attractive) in the works.  Just wait and see.
solidwood
Maple Platform Rack
« Reply #8 on: 18 Feb 2004, 04:08 pm »
I am Making  this now
A rack with 5 shelves 2" thick 24"x16" with 4 maple post 2 1/2 square
 The post will be mounted on the sides and  Dadoed  out 1" deep and 2 " high to fit the shelfs into.
I will bore a pilot hole to screw Lag bolts  into the shelfs to make sure it is good and strong
I will fit it all in the shop and number all the pieces and  all you will have to do is put some glue ( which will make it a lot stronger and stable) or no glue in the dado slots and screw the Lag bolts in   and insert maple plugs to hide the bolts
The post would be on the sides
This will be STRONG and ATTRACTIVE
Marbles
Re: Maple Platform Rack
« Reply #9 on: 18 Feb 2004, 04:24 pm »
Quote from: solidwood
I will fit it all in the shop and number all the pieces and  all you will have to do is put some glue ( which will make it a lot stronger and stable) or no glue in the dado slots and screw the Lag bolts in   and inse ...
How much will this cost?
Got to love Montrose...they were one of the bands at my first concert in the mid 70's.  Sammy Haggar is still one of my favorite (Red) rockers!
solidwood
« Reply #10 on: 18 Feb 2004, 04:40 pm »
Give me a week and I will know exactly, it will be in the area  of $650 and $1000
solidwood
« Reply #11 on: 18 Feb 2004, 04:42 pm »
I also am working on a stackable unit where you can stack as many as you want . One on top of the other
solidwood
solid vs glued platforms
« Reply #12 on: 20 Feb 2004, 09:35 pm »
I made a mistake, my  post is the next one .
solidwood
« Reply #13 on: 20 Feb 2004, 09:40 pm »
There is a lot of talk in the Stereo Forums about Solid vs. Butcher Block
Let me explain what Solid Means or what it dose not mean.
Solid Wood means that the product is made out of all Wood, No Particle Board, MDF. or Plywood.
It does not mean that the Product is one solid piece of Wood without Glue Joints.
All the bigger Blocks have Glue Joints. There are some small blocks up to 11" wide that are one piece but anything bigger is glued together. All the most popular on the Web have glue joints
AND I MEAN ALL
If you think there are some on the market that are solid please email me.
Glue does not hinder the sound of Music, considering the glue in a block soaks into the wood and is then coated with Lacque-polyurethane or another finish.  Musical Insturments are glued together,Guitars are glued together, Violins are glueed together, ect,ect.
A Laminated Block is 10 times as strong as a Single Piece and 10 times less likely to Warp.
All the pieces in a laminated butcher block fight against each other and cannot move.
Therefore they conform to each other and become like one piece of wood and stay very flat.
Air Dried vs. kiln dried
Musical insturments are made out of both Air Dried and Kiln Dried Wood
Kiln dried means - Baked in a oven or dehumidified till the water content of the wood is 7%
Air Dried Means - The wood dries to the amount of moisture in the air, average is 12% to 23%
After wood is kiln Dried and is reintroduced into the atmosphere it also attains the moisture level of the Air that it is in.
If the moisture content of the air is 15% that is what the moisture content of the wood will be
It's like this: In the summer time a wood door will swell up and stick shut but in the winter when your house is real dry the door will open and close very easily.
So whether the block is Air Dried or Kiln Dried does not make one bit of difference
The wood will attain the Humidity of the room it is in.
What makes the difference is THE HUMIDITY OF THE ROOM THE BLOCK IS IN
If you have any comments please feel free to email me Thanks
RooX
« Reply #14 on: 21 Feb 2004, 04:42 pm »
Hi Chris,
Some great looking products chris!  Did you do the stencil work on the fireplace log holder?
Just wondering if you could rattle off a quick quote for a sandbox (the block and box) with a dimension of  14" by 17" In the butcherblock maple.
as well i love the idea of the Cd player curly maple case, care to tell us price wise what we would be looking at?  My player is 13-7/8" x 17" x 3-7/8"
cheers,
Colin Hill
zybar
« Reply #15 on: 21 Feb 2004, 05:11 pm »
Just ordered two 12x15x3 finished cherry amp platforms to put under my Rowland 201 monos.
I am looking forward to adding them into my system.
Chris, how long is it taking to fill an order?
GW
solidwood
Painted flowers
« Reply #16 on: 21 Feb 2004, 05:45 pm »
Colin
They are  not stenciled. They are  painted  free hand
My sister in law is a  Artist. She  did it  and she is really good
Thanks Chris
solidwood
Cherry Amp Platforms
« Reply #17 on: 21 Feb 2004, 05:50 pm »
GW  You should have them in your posession in 2 weeks. I will notify you when I ship. I usually ship within 7 days
Thanks Chris
RooX
« Reply #18 on: 21 Feb 2004, 06:20 pm »
wow chris she is great!  forgive me for thinking its a stencil, i could only ever dream of getting something close to that with a "helping hand"
cheers
solidwood
« Reply #19 on: 4 Mar 2004, 02:44 am »
I would like to thank you all for the "GREAT WELCOME TO YOUR SITE"
You have given me more  projects to build than I ever would of thought
THANK YOU ALL
Chris
