0 Members and 1 Guest are viewing this topic. Read 19659 times.
Looks good! Has kind of a 'muscular' look to it. Is this a sealed cabinet? If so, can I assume it would also work ported if the cabinet was larger? And lastly, what's the approximate efficiency of this design?
You have any plots, FR, and cost? That thing looks awesome I need to hear it at some point.
Rick, The Circondare seems to have similar components to your Cima monitor. On your website, the Cima for some reason does not specify the size of the Illuminator midbass, but comparing them to the RAAL ribbon faceplate, they must be smaller than the 7", perhaps 5.5" or 6"? How does the Circondare TMM compare to the MTM Cima in performance and price? I must admit that I get a little confused with the continual introduction of new models, and don't really know how to compare them, particularly if they are at similar price points. Steve
The Circondare is $2,895/pr. in the standard curved cabinets (gloss black,maple,cherry). The Cima woofer is 5.5". I realize it can be somewhat confusing, similar to seeing a dinner menu with many good dishes to choose from. The benefit is that we can customize to fit your needs rather than offering a one-size-fits-all speaker. That being said, the two designs are different in that the Circondare offers more coverage for standing listeners. It also moves more air and has greater dynamic capability in the bass and mid frequencies. I prefer the aluminum cone resolution of the Circondare's woofer so it would be my choice.
How low will 2 aluminum 5.5" cones go in your cabinet Rick and how much power can they handle? Thanks. Cheers,Robin
The 5.5" isn't available right now with the aluminum cone but I'm working on that.
Yes, I have all the measurements and will post them soon.
If you have them handy, I'm interested in seeing whatever measurements and/or graphs you have on these. Thanks.
Hi Rick,I was wondering, since the cima is still more expensive, is there any reason worthy to opt for cima over the Circondare. I know that you seem to favor the circondare, but the cima are more expensive and i hope it will be justified some where.Thanks
Well it depends on your listening preferences and system. What do you currently have?
I currently have a basic av receiver, acend sierra front. I listen from R&B to jazz to rock, basically everything. Thanks
As an owner of both brands I wouldn't hesitate to buy Selahs. There was online banter about the Sierras vs. the SSRs a while back and the conclusion is that they are in a whole different league. If you prefer paper cones a TMM style Grandeur or SSR would rock the house and might save you a couple bucks
