Best Sub Ever for the $?
0 Members and 1 Guest are viewing this topic. Read 5001 times.
Rick Craig
  • Selah Audio
    • http://www.selahaudio.com
« on: 13 Sep 2010, 03:16 pm »
Here's a picture...
Response graph...
« Last Edit: 14 Sep 2010, 02:49 pm by Rick Craig »
Rick Craig
  • Selah Audio
Re: Best Sub Ever?
« Reply #1 on: 13 Sep 2010, 03:29 pm »
A local audiophile contacted me to design a combination HT/music system. For the subwoofer he was looking at a few well-regarded powered designs. One was beyond his budget and the other too large. I designed this 15" TC Sounds woofer to be driven with a 1000-watt DSP amp. The crossover and equalization curves I programmed for  -3db @20hz bass extension and -6db@60hz Linkwitz-Riley crossover point. This response is +0/-3db so if you use the standard +/-3db curve you can see that the bass extension would be considered around 15hz. Sorry - we don't play the numbers game.   :wink:
This is a sealed cabinet, 19 1/8" x 19 1/8" x 18". We modify it with with additional MDF and composite damping material. The amplifier can be mounted on the rear or placed in an external cabinet. I can also do on-site measuring / programming to adjust for room or placement issues.
Ryan45872
Re: Best Sub Ever?
« Reply #2 on: 14 Sep 2010, 12:21 am »
Where is a pic of the amp? :D
Ryan
Rick Craig
  • Selah Audio
Re: Best Sub Ever?
« Reply #3 on: 14 Sep 2010, 02:20 pm »
Ryan
I had one but with my low $ Nikon I wasn't that happy with the result so I deleted it.  :evil:
Basically a 1000-watt ICE power amp with dual DSP's for very accurate filter control. Balanced input as well.
DFaulds
Re: Best Sub Ever for the $?
« Reply #4 on: 15 Sep 2010, 06:49 pm »
Your thread is best sub for the $, but I couldn't find a price mentioned.
Rick Craig
  • Selah Audio
« Reply #5 on: 16 Sep 2010, 11:06 pm »
$2,295 including shipping to the mainland USA.
J Payton
« Reply #6 on: 27 Sep 2010, 06:11 pm »
Which TC sub is in this design?
Joel
Rick Craig
  • Selah Audio
« Reply #7 on: 27 Sep 2010, 06:21 pm »
Joel
LMS version.
poseidonsvoice
    • 2 channel/7 channel setup
« Reply #8 on: 27 Sep 2010, 06:31 pm »
That's a beauty.
Anand.
jtwrace
    • TIPP YouTube Channel
« Reply #9 on: 27 Sep 2010, 06:36 pm »
That's a beauty.
Anand.
You should get one!   :lol:
