0 Members and 1 Guest are viewing this topic. Read 19616 times.
Haven't you repeatedly said that 7" woofers in a MTM are a bad idea due to driver spacing and beaming issues?
What good is a thread about a new speaker without pictures What a tease
Any more info you can share?
Ok I can name many speakers with two mid-ranges, however all are of the MTM design. So how does the sound of say a (WW)MMT tower compare to the more popular (W)MTM(W)?
Just thinking about how for home theater you would want a matching center channel, how would you make one to go along with these speakers? I believe that you aren't a fan of the MTM center, and for good reason. Just wondering if there's a good way of making a center with 2 mids that isn't MTM. Not saying I'm looking for this, it's just more of curiosity.
You can do a MTM in the center with small diameter mids. What dimensions will your space allow?
Well I'm still trying to finish off the basement so there won't be a size issue, however there will be a placement issue. I can't build a fake wall with and AT screen so it will have to go below the screen and point some what up to the listing position. I like the dual mids for added sensitivity, however it seems that all the high sensitivity mids are 6" and up, I'm thinking higher than 90dbs at 8ohms (if measured with 2.83v). The only ones I know of are the Accutron and AE's new 6.5". Again this is just wondering, not sure yet what I'll do, well other than follow what you do since your price to performance is ridiculously good.
Any update or pictures of the circondare?
