DIY Dodd Buffer
HAL
Re: DIY Dodd Buffer
« Reply #500 on: 28 Jun 2010, 11:25 pm »
Ed,
I have to take the faceplate off, cut the control shafts and put the knobs on.  Did not figure this out until I had the faceplate on.   :duh:
Promise once I have that done will take pics of the unit.
Right now, having to much fun just listening to it!   :thumb:
HAL
Re: DIY Dodd Buffer
« Reply #501 on: 1 Jul 2010, 08:13 pm »
Has anyone tried the Herbie's Audio Lab Ultrasonics Rx9 tube dampers in the buffer?  It will fit on the 6N1P and 6DJ8 family tubes.
jtwrace
    • TIPP YouTube Channel
Re: DIY Dodd Buffer
« Reply #502 on: 1 Jul 2010, 10:43 pm »
On my buffer.... :D
HAL
Re: DIY Dodd Buffer
« Reply #503 on: 2 Jul 2010, 01:21 am »
Any observations on sound quality?
jtwrace
Re: DIY Dodd Buffer
« Reply #504 on: 2 Jul 2010, 01:39 am »
Yes, purchase a pair and try them for yourself.  If you don't like them, return them.
Mine are still on and not going anywhere.
HAL
Re: DIY Dodd Buffer
« Reply #505 on: 2 Jul 2010, 02:15 am »
I only need one for the buffer.   :thumb:
jtwrace
Re: DIY Dodd Buffer
« Reply #506 on: 2 Jul 2010, 02:17 am »
 :duh:  You got a new one.  I have the first version which has two tubes.
dBe
    • PI audio group, LLC
Re: DIY Dodd Buffer
« Reply #507 on: 2 Jul 2010, 03:53 am »
So, you like 'em, eh?  I think I'll have to buy some and give them a shot.  If they're good enough for you, I'm sure they'll work for me.
Dave
HAL
Re: DIY Dodd Buffer
« Reply #508 on: 2 Jul 2010, 12:36 pm »
Dave,
I have the older version Ultrasonics in my battery preamp on the 7308's and they sound really good to me.  Had not heard the newer Ultrasonic Rx version.
dBe
Re: DIY Dodd Buffer
« Reply #509 on: 2 Jul 2010, 03:23 pm »
Dave,
I've been eying them for a while, but didn't know anyone that had actually tried them.  Now I know two.  Cool.  I'll order some today.
Thanks, guys.
Dave
praedet
Re: DIY Dodd Buffer
« Reply #510 on: 2 Jul 2010, 05:14 pm »
Does the gauge of the cable to and from the battery for the buffer matter?
ebag4
Re: DIY Dodd Buffer
« Reply #511 on: 2 Jul 2010, 06:14 pm »
It will matter due to voltage drop but Gary includes a length of red/black zip cord (14 awg?) in with the kit for this.
Best,
Ed
praedet
Re: DIY Dodd Buffer
« Reply #512 on: 2 Jul 2010, 07:56 pm »
I've already built mine with what Gary supplied.  I am making some changes to how I connect to the battery, so I was trying to figure out if a larger gauge would be worthwhile or necessary...
Ted
HAL
Re: DIY Dodd Buffer
« Reply #513 on: 2 Jul 2010, 08:56 pm »
The Neutrik Powercon connector will have a wire gauge limit for the screw down connections.    The small current draw of the buffer will not be a big issue for the 16awg cable supplied in the kit.   If it has to be really long (25'+), then using a larger cable will lower the voltage drop on the wire.
mikeeastman
Re: DIY Dodd Buffer
« Reply #514 on: 2 Jul 2010, 09:12 pm »
Based on the chart I use ,with the 1/2 amp max draw of the buffer,the 14 gauge wire would loss about .5% voltage over 25 ft.
praedet
Re: DIY Dodd Buffer
« Reply #515 on: 2 Jul 2010, 11:33 pm »
What if I am running an amp off the battery, how do I figure out the gauge for that?
mikeeastman
Re: DIY Dodd Buffer
« Reply #516 on: 2 Jul 2010, 11:57 pm »
What is max draw of amp and distance from batt also what % of loss do you want to have?
praedet
Re: DIY Dodd Buffer
« Reply #517 on: 3 Jul 2010, 03:41 am »
I'm looking the Class D amp that is 250 W into 4 ohms, and the Battery will be less than 3ft away...
HAL
Re: DIY Dodd Buffer
« Reply #518 on: 3 Jul 2010, 12:40 pm »
Ok, put the Miniwatt 7308 back in the buffer with an Ultrasonic Rx9 damper.   Sounds very good to me.   Not a huge difference, but things do sound a bit cleaner overall.
I like it! :)
mikeeastman
Re: DIY Dodd Buffer
« Reply #519 on: 3 Jul 2010, 01:30 pm »
According To Gary the 14 gauge wire should be more than big enough for the 3 ft run. He said that his amp only draws 15-20 amp so with 14 gauge you would have only 2% loss during max draw. I am using 10 gauge to keep my loss to 1% or less.
