DIY Dodd Buffer
0 Members and 2 Guests are viewing this topic. Read 305342 times.
praedet
Re: DIY Dodd Buffer
« Reply #520 on: 3 Jul 2010, 01:54 pm »
^^^THanks a lot!!!
Any idea if the Neutrik Powercon connector will accept 10 gauge if I don't use the back piece that screws on?
What about the component side that screws to the backplate, can I use 10 or 8 gauge to that?  Where do I find high quality 8 and 10 gauge wire?
Mariusz
Re: DIY Dodd Buffer
« Reply #521 on: 3 Jul 2010, 02:31 pm »
Please keep it on topic.
Thank You
Mariusz :wink:
mikeeastman
Re: DIY Dodd Buffer
« Reply #522 on: 3 Jul 2010, 04:13 pm »
The Neutrik will accept 10 gauge and you can use all the parts.Probably won't matter on amp side connection but you can use up to 8 guage. All this is based on dodd class-d amp with 12 volt battery, and separate wire to tube buffer and as buffer only draw 1/2 amp max according to Gary the 14 gauge should be more than big enough.
praedet
Re: DIY Dodd Buffer
« Reply #523 on: 4 Jul 2010, 03:07 am »
^^^Thank you very much Mike! That's exactly what I needed to know!
siava1018
Re: DIY Dodd Buffer
« Reply #524 on: 27 Aug 2010, 10:54 pm »
Dodds site says out of stock, Does anyone kno when theyll be back?
TrungT
Re: DIY Dodd Buffer
« Reply #525 on: 27 Aug 2010, 11:10 pm »
Siava
I think about 3 weeks.
But I maybe wrong though.  :oops:
mikeeastman
Re: DIY Dodd Buffer
« Reply #526 on: 20 Sep 2010, 01:58 pm »
Hope this is right place to post this. My Dodd buffer with sandstone top and face plate, still need to find knobs.
buffer in half finished rack.
Gary I will be posting pics of different stone I can make face plates out of and if you see anything you like its yours.
siava1018
Re: DIY Dodd Buffer
« Reply #527 on: 24 Sep 2010, 02:22 am »
any word on when theyll be back in stock?
jtwrace
    • TIPP YouTube Channel
Re: DIY Dodd Buffer
« Reply #528 on: 24 Sep 2010, 11:29 am »
Hopefully for your sake, soon! :thumb:
Mariusz
Re: DIY Dodd Buffer
« Reply #529 on: 21 Oct 2010, 02:41 pm »
Everybody likes to have their RMAF  gear pictures & comments posted except one guy :scratch:
So I help myself and borrow a single picture of Dodd Buffer:
dBe
    • PI audio group, LLC
Re: DIY Dodd Buffer
« Reply #530 on: 21 Oct 2010, 03:13 pm »
Mariusz, where did you get that picture?  It shows the Buffer sitting on top of my buddy Jim's purpleheart feet.  I wonder if there is a picture of the MacSandwich?
Dave
Mariusz
Re: DIY Dodd Buffer
« Reply #531 on: 21 Oct 2010, 03:21 pm »
Check your pm box :thumb:
dBe
Re: DIY Dodd Buffer
« Reply #532 on: 21 Oct 2010, 04:01 pm »
Got it.  Thanks.   :D
Dave
etcarroll
Re: DIY Dodd Buffer
« Reply #533 on: 21 Oct 2010, 07:17 pm »
Is that birdseye maple, it's gorgeous!
Mariusz
Re: DIY Dodd Buffer
« Reply #534 on: 21 Oct 2010, 07:55 pm »
I didn't take the picture. I wasn't even at the RMAF show. But yeah, it looks like it.
dBe
Re: DIY Dodd Buffer
« Reply #535 on: 21 Oct 2010, 08:11 pm »
That is quilted maple with a natural oil finish on it.  Mine are the same and freakin' gorgeous.
Mr. Dodd does good work.   :thumb:
Dave
TrungT
Re: DIY Dodd Buffer
« Reply #536 on: 21 Oct 2010, 08:30 pm »
Showed off  :thumb:
dBe
Re: DIY Dodd Buffer
« Reply #537 on: 21 Oct 2010, 08:40 pm »
Showed off  :thumb:
Trung, that paduk is absolutely awesome!
Dave
siava1018
Re: DIY Dodd Buffer
« Reply #538 on: 21 Oct 2010, 09:20 pm »
very jealous
Rclark
Re: DIY Dodd Buffer
« Reply #539 on: 29 Oct 2010, 07:33 am »
 Question guys.
I know this is all hypothetical, but tell me if you think a Dodd Buffer would be good in my situation:
 So I've got an Emotiva ERC1 player, and I'll be getting soon the XDA-1 DAC. My plan now is to run ERC-1 and whatever else I get into (PC audio, etc) into the XDA-1 and the XDA-1 directly into the amplifier.
The XDA-1 apparently works really well straight into the amplifier and outputs 12Volt peaks and I think like 2 amps. It's supposed to sound really nice.
 However, it has a digital volume control. Now while nobody knows how well theirs is implemented, do you think that by placing a Dodd Buffer between the XDA-1 (just turn it all the way up) and the amp, that I could get... even better sound?
So ERC-1 -> XDA-1 -> classD amp
or ERC-1 -> XDA-1 - > Dodd buffer -> classD amp?
