DIY Dodd Buffer
ltr317
Re: DIY Dodd Buffer
« Reply #580 on: 16 Nov 2010, 10:51 pm »
I believe it's called Vacuum Mummification. Easily extends tube life to thousands of years. :lol:
Actually, if it's teflon or plumber's tape, it will shorten tube life, as it will not get proper heat dissipation.
Mariusz
Re: DIY Dodd Buffer
« Reply #581 on: 17 Nov 2010, 01:14 am »
Hey Paul
What if say, Teflon tape (plumbers tape) is used only at the bottom or top part of the tube? Would that be acceptable proposal for inexpensive "tube dumpping tweak"???
Question is a bit off topic but interesting nevertheless.
M.  :thumb:
ltr317
Re: DIY Dodd Buffer
« Reply #582 on: 17 Nov 2010, 01:33 am »
Hey Paul
M.  :thumb:
Hi Mariusz,
Well, you would have to wrap the tape many times around the tube in a small area to allow heat dissipation.  But why would you want to do that?  You can buy cheap tube dampers that will do the same thing.  Don't forget, dampers are to help with microphonic tubes, not noisy tubes.  Nothing helps with noisy tubes, except once in a while you get lucky if you thoroughly clean the pins.  From my long experience, that only works about 5% of the time, and I may be generous with the percentage.  :D
G.Michael
Re: DIY Dodd Buffer
« Reply #583 on: 17 Nov 2010, 04:01 pm »
Hi Trung,
Questions:
--What does the teflon tape do for the sonics?
--The big heat sink, what heat is that dissipating?  It doesn't look as though it's doing much to help the tube.
--It that a toggle switch next to the bottom corner of the heat sink?  What's that do?
TrungT
Re: DIY Dodd Buffer
« Reply #584 on: 19 Nov 2010, 07:38 am »
Michael
Teflon tape act just like the tube damper. (I don't have to buy tube damper and I'm cheap  :thumb: , I have few feet of Teflon tape here already)
If you worry about heat, just wrap one line, since the tube I using does not put out much heat anyway. How does it sound, try it and find out :wink: , if you don't like it, just take it off.  :duh:
Big heatsink is for the 6V voltage regulator, when 6H30 tube is in use, it does draw more amp than stock tube, so more heat, bigger heatsink (may be little over kill on my buffer)
Toggle switch, just switch 12V or 6V , you can use 12V or 6V tube on the buffer.
Hope that help.
praedet
Re: DIY Dodd Buffer
« Reply #585 on: 19 Nov 2010, 06:12 pm »
Well, here is my finished power source for the buffer.  I think I am going to get a 2nd buffer as I want one with a HT bypass ;)
dBe
    • PI audio group, LLC
Re: DIY Dodd Buffer
« Reply #586 on: 19 Nov 2010, 06:50 pm »
AWESOME!!!
Good job.   :thumb:
Dave
TrungT
Re: DIY Dodd Buffer
« Reply #587 on: 20 Nov 2010, 03:54 am »
Praedet
Awesome.
Here another Dodd buffer build:
Solidworks for the drawing.
Chassis from here http://www.circuitspecialists.com/prod.itml/icOid/6051
more soon
Mariusz
Re: DIY Dodd Buffer
« Reply #588 on: 20 Nov 2010, 04:08 am »
Hey Trung
I was going to ask: where did you get that metal case?
And what dimensions is it? (looks close to 8x12x3 ?)
I'll post some pics soon as well. Heat sink, knobs, polyurethane on faceplate should be done this weekend..............ofcause, I wouldn't accomplished a thing without your help and advice.  :notworthy:  :beer:
TrungT
Re: DIY Dodd Buffer
« Reply #589 on: 20 Nov 2010, 04:13 am »
Mariusz
You'r welcome  :thumb:
11.9''(L)x7.5''(W)x2.9''(H)
Mariusz
Re: DIY Dodd Buffer
« Reply #590 on: 20 Nov 2010, 04:50 am »
Great link Trung.
Found few things which are just perfect for other projects.
Thanks again.  :thumb:
TrungT
Re: DIY Dodd Buffer
« Reply #591 on: 20 Nov 2010, 08:22 pm »
More to come .....
HAL
Re: DIY Dodd Buffer
« Reply #592 on: 20 Nov 2010, 08:56 pm »
Trung,
Looks very nice!   :thumb:
I think I have an idea of how to get the BIG heatsink in the standard chassis and not move things to much.  Will see if I can find some tall stand-offs for the four corner holes!  Then is should sit above the big power module and have cooling around the bottom and top.
TrungT
Re: DIY Dodd Buffer
« Reply #593 on: 20 Nov 2010, 09:10 pm »
Hal
Great ideal, look much nicer than those cable tie.  :duh:
May have to "re-mod" my heatsink.  :icon_twisted:
TrungT
Re: DIY Dodd Buffer
« Reply #594 on: 21 Nov 2010, 01:45 am »
Mariusz
Re: DIY Dodd Buffer
« Reply #595 on: 21 Nov 2010, 02:57 am »
Your teflon tweak inspired me a bit and since it is a slow night at work and not much happening in collage football, here is another idea:
« Last Edit: 21 Nov 2010, 05:43 am by Mariusz »
nodiak
Re: DIY Dodd Buffer
« Reply #596 on: 21 Nov 2010, 03:33 am »
"and not much happening in collage football"
Arkansas vs Mississippi State is a good one!  :lol:
But braiding teflon tape for tube dampers is diy heroic man!
TrungT
Re: DIY Dodd Buffer
« Reply #597 on: 21 Nov 2010, 03:40 am »
Mariusz   :bowdown:
 :wink:
Mariusz
Re: DIY Dodd Buffer
« Reply #598 on: 21 Nov 2010, 03:50 am »
I was watching ND v.s Army.
Nebraska v.s Texas looks promising tho.
And that's not an act of desperation but boredom. :icon_lol:
« Last Edit: 21 Nov 2010, 05:47 am by Mariusz »
TrungT
Re: DIY Dodd Buffer
« Reply #599 on: 21 Nov 2010, 05:43 pm »
