0 Members and 1 Guest are viewing this topic. Read 19777 times.
FellasI picked up a pair of 15" Geddes waveguides with foam plugs and B&C DE-250 drivers off of the 'Gon.-Jim
So I see you are in the process of building the Harpers. Do you intend to use these together or anything?-Tony
Quote from: JDUBS on 11 Dec 2009, 02:19 amFellasI picked up a pair of 15" Geddes waveguides with foam plugs and B&C DE-250 drivers off of the 'Gon.-JimHow much did you pay for this combo, 15" waveguide and foam? Thanks
Quote from: ttan98 on 11 Dec 2009, 03:53 amQuote from: JDUBS on 11 Dec 2009, 02:19 amFellasI picked up a pair of 15" Geddes waveguides with foam plugs and B&C DE-250 drivers off of the 'Gon.When drivers you mean just the DE250 not including the AE 15"? If $750 include both drivers then $750 is well priced.-JimHow much did you pay for this combo, 15" waveguide and foam? Thanks$750 for the waveguides, drivers, foam plugs, and crossovers.-Jim
Now I need to figure out how to best mount them in my Yorkville cabinets. I knew the outer diameter of the waveguide would be right at the opening size previously occupied by the unity horn. I think some sort of support for the driver side with a flat base should work. Hmmm...now I just need to figure out how to cobble together something using readily available stuff from home depot. Any suggestions?
Any update here?
Wayne, I like the Yorkville woofer, too. I think you had previously linked to Eighteen Sound article on building a 2-way speaker using this driver. Looks like you can cross it at up to 2,000hz...so, I hope 900hz works well.
