0 Members and 1 Guest are viewing this topic. Read 19769 times.
900hz wouldn't work here - B&C DE 250 is specified as 1k-18k with recommended crossover freq of 1.6kyou would need a bass driver capable of going much higher - quite a difficult task - something like 20hz-2k or so.....
Sorry but you are being too literal with the specs. The driver is rated for pro use, as in 120db. For home use, you most definitely can drive these down to 800hz. The poly phragm has a big factor in this too. Geddes said he crosses around 800hz now. I don't know if he used to cross at 900hz before.
interesting post. i've always thought that the measurements are an exact data which is irrelevant of the way of use - pro or home. how can a driver specified for particular linearity over certain frequency range achive a desired linearity outside of the specified range? can you really improvise here? am i missing something?
If the directivity matches, I'd bet you can't hear it. I know I can't. Prior to my current speaker, I've heard every crossover w/ the exception being fullrangers.Dan
Something else. Homemade jobbies, but match criteria fairly well.This is not a simple project. Good luck. There will be plenty to help along the way.
i'm wondering what data exactly shows that a bass driver has a 90 degrees directivity at 900hz? i may be interested in trying some other woofers that looks better in other areas than B&C, most notably like BD15 or a beyma 115ND/W....
Without having any first-hand knowledge, I would think that you could make an excellent speaker with the AE TD15M plus Earl's waveguide and B&C DE250.However, you'll be back to square one in terms of the crossover. If you relish a substantial challenge, and we're in The Lab after all, it could be a very rewarding project. Of course, it could also be completely maddening, costing you time and money, and you might never finish the speakers.I did a 12" midbass + horn/compression driver as my first multiway project, and the crossover between the midbass and horn took >1 year. I'm a bit slow at finishing projects, but an awful lot of that time was learning the basics. And while I'm a proponent of reading the classics on loudspeaker design and measurement, there are some things that you just need to learn first-hand.John
