Dodd Buffer
0 Members and 1 Guest are viewing this topic. Read 60288 times.
ebag4
Re: Dodd Buffer
« Reply #120 on: 19 Feb 2010, 01:10 am »
I miss my buffer already...it's only been 5hrs.  I plugged another piece in so I could listen and OMG.   :nono:  This isn't working...so bad I shut it down.   :duh:
Can't wait for the upgraded buffer to come back.  Make it happen Gary! :thumb: :green:
Jason,
Have you moved back to your monos or are you still running the ClassD?
Best,
Ed
jtwrace
    • TIPP YouTube Channel
Re: Dodd Buffer
« Reply #121 on: 19 Feb 2010, 01:11 am »
Got the monos hooked up now....Class D is getting "rebuilt" with the IR board and case.
dBe
    • PI audio group, LLC
Re: Dodd Buffer
« Reply #122 on: 19 Feb 2010, 01:46 am »
Would one of you guys who currently own the buffer please give me a width and thickness measurement of the faceplate.  I am building an enclosure for a amp and I would like to build a matching case for it.  It will be a bit taller but I can match width.
Ed
Mine is 8-15/16" x 3-15/16" x 3/4".  The corner roundovers are 3/16" and the face and back roundovers are 1/8"...ish... they've been sanded a bit.
BTW.  I feel for Jason and his withdrawal symptoms.
Dave
ebag4
Re: Dodd Buffer
« Reply #123 on: 19 Feb 2010, 01:49 am »
Dave
Thanks for taking the time to do good measurements Dave, much appreciated.
Best,
Ed
dBe
Re: Dodd Buffer
« Reply #124 on: 19 Feb 2010, 03:51 am »
Best,
Ed
Happy to do so, Ed.
Dave
ebag4
Re: Dodd Buffer
« Reply #125 on: 22 Feb 2010, 05:24 pm »
Gents,
Sorry to hit you up for dimensions again but I am getting ready to build a box for my amp and I want to ensure it will match nicely with the Dodd Buffer.  Dave has given me the dimensions of the faceplate but I want to make certain I have the dimensions of the box correct as I plan to stack them.  Gary's website says the dimensions are 9"x8"x4", is this inclusive of the faceplate? That would make the box 9"(actually probably a 1/4" less as the faceplate is a bit wider than the box)x7.25"x4", is this accurate?
edit: I am looking for the backbox measurements minus any connector lengths or faceplate.
Ed
Danny Richie
Re: Dodd Buffer
« Reply #126 on: 22 Feb 2010, 05:26 pm »
You might ask Gary if he can sell you a blank chassis. They'd match for sure then.
ebag4
Re: Dodd Buffer
« Reply #127 on: 22 Feb 2010, 05:29 pm »
Thanks Danny, I considered it.  Unfortunately the amp I am building will not fit in the chassis Gary is using.  I will be able to match the width and the depth but the box I am building will be 5.5" tall.
Best,
Ed
TrungT
Re: Dodd Buffer
« Reply #128 on: 22 Feb 2010, 05:31 pm »
8.5" X 7.5" X 3.5"
 :thumb:
ebag4
Re: Dodd Buffer
« Reply #129 on: 22 Feb 2010, 05:32 pm »
8.5" X 7.5" X 3.44"
 :thumb:
Thanks TrungT, I appreciate it.
Best,
Ed
TrungT
Re: Dodd Buffer
« Reply #130 on: 22 Feb 2010, 05:35 pm »
Your Welcome.
Just made a correction.  :duh:
I need sleep some more  :oops:
ebag4
Re: Dodd Buffer
« Reply #131 on: 22 Feb 2010, 05:39 pm »
Your Welcome.
No worries, my chassis height is different anyway.
Thanks again.
Best,
Ed
dBe
Re: Dodd Buffer
« Reply #132 on: 22 Feb 2010, 06:44 pm »
Gents,
Ed
Ed,
7-1/2" deep x 8-5/8" wide x 3-1/2 tall - metal enclosure dimensions only.
I like Danny's idea.
HTH
Dave
ebag4
Re: Dodd Buffer
« Reply #133 on: 22 Feb 2010, 06:54 pm »
Ed,
HTH
Dave
Thanks again Dave.  I like Danny's idea as well, unfortunately there is no way I can get this amp to fit in that chassis, I have to go taller to mount the boards vertically.
Best,
Ed
jtwrace
Re: Dodd Buffer
« Reply #134 on: 25 Feb 2010, 02:42 pm »
My buffer is on its way back from the Cap upgrade...
Thanks Gary!   :thumb:   :green:
dBe
Re: Dodd Buffer
« Reply #135 on: 25 Feb 2010, 03:05 pm »
WooHoo!!!  All kinds of good things are coming your way!!
 :eyebrows:
Dave
saisunil
Re: Dodd Buffer
« Reply #136 on: 25 Feb 2010, 03:19 pm »
Anyone compared the buffer with dodd battery pre?
Are there any sonic differences (not gain related) - does the buffer lack in anyway - drive / dynamics of the battery pre.
Sunil.
jtwrace
Re: Dodd Buffer
« Reply #137 on: 25 Feb 2010, 03:50 pm »
Sunil.
A birdie told me that the buffer was actually better.  I'm sure Gary would be the best to answer this question though.
Gary?
gld
    • http://doddaudio@live.net
Re: Dodd Buffer
« Reply #138 on: 25 Feb 2010, 09:43 pm »
I can answer this question. There are 3 differences between the preamp and the buffer.
1. the buffer has no HT bypass, the preamp does.
2. The buffer has a set of fixed outs, the preamp doesn't
3. The buffer has NO gain, the preamp has 16db of gain
Now for the sonic differences. Danny and I both have a-b'd between the pre and the buffer, him in his system and myself in my system. We both found that if you use the same tubes in each device that they sound exactly the same, neither of us could detect any differences. I personally like the buffer due to the wide range of use with the volume control, but on the days when I need Chinese drums at 115db levels, :drool: I must use the preamp! So in this case I cannot say 1 is better than the other. It's more like both are wonderful which 1 do I want! :eyebrows:
Gary
ctviggen
Re: Dodd Buffer
« Reply #139 on: 25 Feb 2010, 09:58 pm »
I bought the Pre over the buffer for the HT bypass and the dB of gain.  My modified Squeezebox doesn't have enough gain.
Now, to find some used Dodd amps, and I'll be all set!
