Dodd Buffer
0 Members and 1 Guest are viewing this topic. Read 60280 times.
cujobob
Re: Dodd Buffer
« Reply #100 on: 24 Jan 2010, 01:03 am »
If this has been asked, apologies, but is there a way to hook up a sub (or several)?
S Clark
Re: Dodd Buffer
« Reply #101 on: 24 Jan 2010, 01:16 am »
You should be able to go from output 2 to your sub.  :thumb:
ebag4
Re: Dodd Buffer
« Reply #102 on: 10 Feb 2010, 05:36 pm »
Can someone give me an idea of the ah rating or the battery vs the playing time of the buffer.  I read the thread but didn't find it.
Ed
jtwrace
    • TIPP YouTube Channel
Re: Dodd Buffer
« Reply #103 on: 10 Feb 2010, 05:42 pm »
If I remember correctly, it's ~2 hour per ah.  The draw is dependent on the tube used but 700ma is what I remember to use...
Gary?
dBe
    • PI audio group, LLC
Re: Dodd Buffer
« Reply #104 on: 10 Feb 2010, 06:04 pm »
Gary?
Yep, with the Amperex 7308s mine is drawing about 780 ma according to an old simpson meter I have.  I figure an hour and a half per AH.  Of course I have a 100AH battery, so.............. :thumb:
Dave
ebag4
Re: Dodd Buffer
« Reply #105 on: 10 Feb 2010, 06:06 pm »
Close enough, thanks for the replys guys.
Best,
Ed
jtwrace
Re: Dodd Buffer
« Reply #106 on: 10 Feb 2010, 06:06 pm »
Best,
Ed
no problem.   :thumb:  Are you getting one?
ebag4
Re: Dodd Buffer
« Reply #107 on: 10 Feb 2010, 06:13 pm »
I'm considering it.  I would need to sell my Jolida 102B.  I would be running a self modded T-amp (at least for a while) into a pair of Danny's V-1 coaxs.  I already have 10 ah of SLA batts with charger and enclosure available from an old amplifier build.
Best,
Ed
jtwrace
Re: Dodd Buffer
« Reply #108 on: 10 Feb 2010, 06:18 pm »
Best,
Ed
Great!
Maybe Danny will loan you his...I would if I were closer, I would.
I don't know anything about the Jolida but you will NOT be disappointed.  This buffer replaced a VERY high dollar tube pre.  I say, GO FOR IT!!!! :green:
ebag4
Re: Dodd Buffer
« Reply #109 on: 10 Feb 2010, 06:20 pm »
Great!
What amp and speakers are you driving?
jtwrace
Re: Dodd Buffer
« Reply #110 on: 10 Feb 2010, 06:52 pm »
amps are Clayton Audio M-300's
Speakers are currently a custom 3-way I built.
ebag4
Re: Dodd Buffer
« Reply #111 on: 10 Feb 2010, 08:45 pm »
Nice Amps! :drool:
Also waaay out of my league.  Of course with 96dB speakers I won't need anything close to that amount of power.
Best,
Ed
jtwrace
Re: Dodd Buffer
« Reply #112 on: 10 Feb 2010, 08:56 pm »
Best,
Ed
I had electrostats before the 3 way...I've also been playing with the Class D audio amps.
jtwrace
Re: Dodd Buffer
« Reply #113 on: 11 Feb 2010, 02:32 pm »
Best,
Ed
Great news!
See this thread:  http://www.audiocircle.com/index.php?topic=77308.msg733865;topicseen#new
ebag4
Re: Dodd Buffer
« Reply #114 on: 11 Feb 2010, 02:37 pm »
Great news!
Thanks for the heads up!  I am still wrestling with this a bit.  I have too many things changing at once.  I think I will probably wait until after I have completed my V-1s (hopefully within the next month) and then take stock of the rest of the system to determine where my limited audio funds should go next.
Thanks again.
Best,
Ed
Flyin_V
Re: Dodd Buffer
« Reply #115 on: 16 Feb 2010, 02:23 am »
This battery thing sounds very cool. I see someone mentioned a 'pulse' charger; is there a non pulse charger that could be used while the amp/buffer is being used?
I'm familiar with RWA, is there a charging system like their's and how much would all that stuff cost? I think it would have to be at least 50AH for extended playing time if it couldn't charge while in use.
Thanks.
A. Battery Neophyte  :green:
jtwrace
Re: Dodd Buffer
« Reply #116 on: 16 Feb 2010, 02:26 am »
Thanks.
See my post in the begining of this thread (post #39)....all of that cost $80.  Yes, battery and charger.  You can use a non pulse charger such as a battery tender.  No need though.  Just get a good battery with the desired ah rating (about 1.5hrs per ah) and go!  This is one of the best pieces of gear I've ever bought.
  https://www.shopatron.com/products/productdetail/part_number=56-171/560.0.23205.0.0.0.0
dBe
Re: Dodd Buffer
« Reply #117 on: 16 Feb 2010, 02:48 am »
+1 on that.  The total lack of noise and the dynamic contrasts are pretty amazing
Dave
jtwrace
Re: Dodd Buffer
« Reply #118 on: 19 Feb 2010, 01:07 am »
I miss my buffer already...it's only been 5hrs.  I plugged another piece in so I could listen and OMG.   :nono:  This isn't working...so bad I shut it down.   :duh:
Can't wait for the upgraded buffer to come back.  Make it happen Gary! :thumb: :green:
ebag4
Re: Dodd Buffer
« Reply #119 on: 19 Feb 2010, 01:08 am »
Would one of you guys who currently own the buffer please give me a width and thickness measurement of the faceplate.  I am building an enclosure for a amp and I would like to build a matching case for it.  It will be a bit taller but I can match width.
Ed
