Dodd Buffer
HAL
Re: Dodd Buffer
« Reply #180 on: 18 Apr 2011, 02:08 pm »
Jason,
IIRC, Scott has a Dodd Audio Battery Preamp like mine.
dBe
    • PI audio group, LLC
Re: Dodd Buffer
« Reply #181 on: 18 Apr 2011, 02:32 pm »
I can't think of a bigger value in audio when it comes to preamps.  I love mine.  I replaced a much modified Cary SLP-50B and the Dodd is more open sounding - I do have Platinum bypasses on the output section, BTW.
Dave
TrungT
Re: Dodd Buffer
« Reply #182 on: 18 Apr 2011, 02:40 pm »
I only have 3 Dodd buffers.
 :thumb:
jtsnead
Re: Dodd Buffer
« Reply #183 on: 18 Apr 2011, 02:51 pm »
Dave
DITTO  :icon_lol:
ebag4
Re: Dodd Buffer
« Reply #184 on: 18 Apr 2011, 03:00 pm »
Dave
Ditto x2...I love mine!
I also converted the tape out to a volume controlled output hi-passed at about 140Hz using a sonicap platinum.
With regard to tubes I would make a b-line to the 6H30, I am using a Pi version but many say the DR version is another step up.  To use the 6H30 you have to add a heatsink to the voltage regulator but doing this during initial assembly should be easier than retrofitting it later as I did.
Best,
Ed
mikeeastman
Re: Dodd Buffer
« Reply #185 on: 18 Apr 2011, 03:05 pm »
Ditto x 3. I've had mine for about a year and just got 2 more to mate with class d amps I'm building.
   Mike
S Clark
Re: Dodd Buffer
« Reply #186 on: 18 Apr 2011, 03:14 pm »
Jason,
Bingo!! The buffer adds a tiny bit more detail (some of which could be the platinum bypass) and a bit wider soundstage.  But the differences are very noticeable.
To better the full preamp, which along with the Modwright, were the top in their class, is a feat in itself.  To do it at an amazing value, is stunning.  I have said it before, and if it falls into the realm of fanbo_ I really don't care, Gary Dodd is an absolute genius when it comes to sound.
HAL
Re: Dodd Buffer
« Reply #187 on: 18 Apr 2011, 03:25 pm »
+1 to what Scott said!
I am building one for a friend to  try with the 6H30PI.  Just the input board to finish.  This will also have the Platinum bypass caps.
Maybe someone needs to build a demo unit for a tour.
Just a thought.
dBe
Re: Dodd Buffer
« Reply #188 on: 18 Apr 2011, 03:53 pm »
Best,
Ed
Ed, did you use a .47 or what?  I could figure it out, but asking you is easier.  I've had grandkids for a week and my brain has been turned to jelly   :duh:
Thank you, sir.
Dave
NeilT
Re: Dodd Buffer
« Reply #189 on: 18 Apr 2011, 03:54 pm »
OK, thanks for the feedback. Looks like a no-brainer decision.
It looks an easy / straight forward build?
Any tricks or things I should know to make it go smoother?
I am building a case from scratch.
I did not see any venting on the metal case on his site?
Thanks again for the feedback
Neil
ebag4
Re: Dodd Buffer
« Reply #190 on: 18 Apr 2011, 03:57 pm »
Thank you, sir.
Dave
Hi Dave,
Yes, .047uF.  That is what was recommended to me by Danny and Gary.  BTW, if you are converting the tape out you will also need a 1K resistor:
Best,
Ed
ebag4
Re: Dodd Buffer
« Reply #191 on: 18 Apr 2011, 04:01 pm »
Neil
Hi Neil,
Gary's case has side vents.  I vented mine in the top.  It may not be necessary but IMHO venting electronics and trying to keep them cool is never a bad idea.  Here is mine:
Good luck!  (You won't need it, very easy build)
Best,
Ed
dBe
Re: Dodd Buffer
« Reply #192 on: 18 Apr 2011, 04:10 pm »
Hi Dave,
Yes, .47uF.  That is what was recommended to me by Danny and Gary.  BTW, if you are converting the tape out you will also need a 1K resistor:
Best,
Ed
Great Ed, thanks.  I thought that was the value.  The pic sure helps, too.
My best.
Dave
NeilT
Re: Dodd Buffer
« Reply #193 on: 18 Apr 2011, 04:13 pm »
Thank you ED,  :thumb: :thumb:, looks great.
A picture is worth a whole bunch of words.
Is your's all wood, with just the metal plate in back for the RCA's.
Do any of the components need a heat sink?
Any chance, I could take a peek inside to see your layout?
Anyone else like to share some photos of their builds?
Neil
ebag4
Re: Dodd Buffer
« Reply #194 on: 18 Apr 2011, 04:17 pm »
My best.
Dave
Sorry Dave, I mistyped, the value is actually .047uF as shown on the drawing (now fixed in my post).  Sorry for the confusion.  Here is the response I received from Danny when I asked:
"By the math a .047uF looks to be just right for the impedances of the amp that I am using and for those speakers. "
Best,
Ed
NeilT
Re: Dodd Buffer
« Reply #195 on: 18 Apr 2011, 04:20 pm »
Hey Ed,
Did you make your own faceplate?
Does anyone ever use the mute switch?
Nevermind, I see that it is also a power switch.
Neil
ebag4
Re: Dodd Buffer
« Reply #196 on: 18 Apr 2011, 04:28 pm »
Neil
Sure Neil, I don't currently have any pics of it in it's current state (added heat sink, now running from external AGM battery) but here a few from the original build.  BTW, yes, it is all wood except for the rear plate (wood was too thick for the RCAs and screen on top).  I will mention that I have a ClassD amp in a similar case (all wood) and the buffer and amp cannot be placed close together due to some electrical noise (generated by the ClassD amps transformer I believe).
edit, I did have a pic of the heat sink!
edit #2, yes, I made the faceplate.  After seeing my poor attempt to do something similar for my classD amp Trung recommended I try a woodburner, you know, like you used in cub scouts  :lol:.  This worked out pretty well, however if I were to do it again I would probably forgo the $15 woodburner and just have a local shop do a laser engraving for $30  :duh:
Best,
Ed
dBe
Re: Dodd Buffer
« Reply #197 on: 18 Apr 2011, 04:49 pm »
Best,
Ed
Hmmmmm. Ed, I could have sworn that the needed value was .47.
Thanks again.
Dave
NeilT
Re: Dodd Buffer
« Reply #198 on: 18 Apr 2011, 04:56 pm »
Your faceplate looks very good and thank you for all the pics.
I am thinking external bats are the way to go?
Neil
ebag4
Re: Dodd Buffer
« Reply #199 on: 18 Apr 2011, 05:05 pm »
Thanks again.
Dave
Dave, I am not sure what to tell you because I didn't come up with the value myself.  The response above was a quote from the PM Danny sent me, here is a pic of the cap he sent me installed in the buffer.
If you learn it should be something different please let me know.  It is difficult for me to hear the difference due to the coax of the V1 being hi-passed at 200 Hz anyway, so the advantage gained with the hi-pass cap in the Dodd is just to relieve the amp from playing the low bass.
Best,
Ed
