0 Members and 1 Guest are viewing this topic. Read 32712 times.
That NS-6N7 description sounds pretty sweet.
Hello EverybodyYou might be aware of our Classic Series amplifiers. We can make new amplifiers using the iron from vintage amps. If you have an amplifier that's not working so well any more and there's simpley too much wrong with it- we can recover all the transformers, place them in a new enclosure and provide a new circuit for them to run in with all new parts. If the amplifier has a bad power transformer, the output iron can still be used. Get this: Even if an output transformer is fried, we can get a substitute for it! If you want something new to listen to and a chance to save ALLOT of money (because transformers are expensive), we know you will like this approach. There's no reason why that old (or new) tube amplifier should be sitting around doing nothing.
Take a look at our F2A Single Ended amplifier:
You asked for criticism, so... The on/off switch is cheap and tacky, and while some like the "chicken head", knobs, I do not.That said the fit and finish appear to be quite well done and in line with your "50's quality and solid product approach. I suppose the knobs go along with this theme, but the power switch is unacceptable in my opinion.
Don't like my power switch... geez. Ok- I will look into other varieties. I was also thinking about wood trim and various other nifty things. Great comments!
