Now I Need A New Rack!
0 Members and 1 Guest are viewing this topic. Read 27470 times.
Robert D
Re: Now I Need A New Rack!
« Reply #60 on: 8 Oct 2009, 12:27 am »
Keith thats great News
I knew that they would help you out
A good Group of hard working Guys
Robert
racerxnet
« Reply #61 on: 8 Oct 2009, 01:09 pm »
My wife could use a new rack too.    :)
Levi
« Reply #62 on: 8 Oct 2009, 01:30 pm »
I am using Salamander rack.  It's cheaper than most racks out there and you can hide your components.  My wife likes it.
alexone
« Reply #63 on: 8 Oct 2009, 02:19 pm »
Levi,
what about ventilation? do you leave the doors open while the equipment is in use?
btw, i like the "hiding" of electronics...
al.
Levi
« Reply #64 on: 8 Oct 2009, 02:26 pm »
Hi Al, the back of the Salamander rack is open.  The doors are perforated so it is has good ventilation.
Just because my tube preamp runs extremely hot, I made my own 70mm computer fans and mount it in the back.  Also, Salamander sells fans for the rear if you are not into diy.
toobluvr
« Reply #65 on: 8 Oct 2009, 07:05 pm »
Don't let her hear ya making that crack!!
 :o       :surrender:
1ZIP
« Reply #66 on: 9 Oct 2009, 02:18 am »
I also have the salamander cabinet...Sedona I think.  The back can be open or with fans, also the bottom shelf's have slots in them to aid in cooling.  I believe that you can also get slotted shelves to replace the solid mid and upper shelf.  It can be configured almost anyway you want and there are a batch of accessories you can also get, like lighting, fans, different feet, perforated doors and sides or no doors, additional shelves, plus it is a well built nice looking piece of furniture with  3 - 4 different styles.  True it doesn't have the resonance damping or the esoteric look and associated price tag, but it is a handsome piece of furniture and a good way to set off the minimalistic  design of the Bryston gear.  No, I don't own any Salamander stock!
KeithA
« Reply #67 on: 16 Oct 2009, 03:49 pm »
Well
 until I get the new racks...I needed a way to get the gear off the floor.
So, I took the hacksaw to my old stand :o
Looks kinda neat, actually :D
Keith
Robert D
« Reply #68 on: 16 Oct 2009, 04:26 pm »
Keith did you Order from Sons Ideal Claude ............
Let us Know
Robert
Laundrew
« Reply #69 on: 16 Oct 2009, 08:43 pm »
Awesome looking Macs Levi :thumb: I would not want to hide them :nono:
Be well...
BrystonFan
« Reply #70 on: 16 Oct 2009, 10:18 pm »
Levi: Is that the cherry wood rack with the perforated steel doors?
I'm looking to get a twin-30 in walnut...
alexone
« Reply #71 on: 17 Oct 2009, 02:06 pm »
Well
Keith
Keith,
the center speaker is located in the very back...does it work proper?
al.
Levi
« Reply #72 on: 17 Oct 2009, 03:55 pm »
Thank you for the vintage McIntosh complement.  :) I use it sparingly and even if I want to hide it, there are no more space in the rack! :lol:
The rack is walnut with walnut perforated steel doors and walnut sides.
--Levi
KeithA
« Reply #73 on: 17 Oct 2009, 04:58 pm »
Well
Keith
Keith,
al.
Good one  :lol:
It's not even hooked up in the pic. It will be installed above the TV, on it's own shelf :lol:
Keith
Levi
« Reply #74 on: 17 Oct 2009, 05:20 pm »
Not a good idea.
Laundrew
« Reply #75 on: 17 Oct 2009, 06:01 pm »
srb
« Reply #76 on: 17 Oct 2009, 06:21 pm »
Because if instead it's placed below the TV, it will be more in line with the left and right speakers and closer to ear level.
b5pt9
« Reply #77 on: 17 Oct 2009, 06:48 pm »
Yes ideally the center speaker mid&tweeter would be at same elevation as left/rights.  Immediately below TV would be ideal in the setup pictured.
*edit for better grammar
« Last Edit: 17 Oct 2009, 11:25 pm by b5pt9 »
KeithA
« Reply #78 on: 17 Oct 2009, 09:17 pm »
Then I guess I'll just have to get my ears raised :wink:
We all know what the 'optimum' setup would be. But, it's all about trade-offs from time to time.
For 7 years the centre channel was well above the plane of the LR fronts as it sat atop a massive rear projection TX. It was angled down towards me.
Sounded great....the plan was to put the centre channel below the TV....but created other problems with audio racks, cabling, etc.
So, as far as 'Not a good idea goes".........no merit in that one for me :wink:
Putting it below the TV is still not 100% ruled out, but it would change the path I've chosen for audio racks and requires many new cables :wink:
Keith
Levi
« Reply #79 on: 17 Oct 2009, 09:36 pm »
That is why the rack in the center does not work for you. You can raise the L and R speakers so thay are inline with the center channel. :thumb:  problem solved!
