0 Members and 1 Guest are viewing this topic. Read 23313 times.
Good advice Bryan [ as always] . Maggies love diffusion behind them as well as an absorbing rear wall. BTW put those tweeters on the outside and toe in about 3 inches or so. Depending on room size try about 7 feet apart for starters. Try using brass cones to lift them off the floor. A rear brace will also add to the performance. Check out Mapleshade Maggie stands for ideas.
...A bit more info can be found atwww.barrydiament.com/monitoring.htm
Barry:Need a little clarification if you don't mind.I own a pair of Apogee Ribbon speakers and reading their users forum, it appears that many Apogee owners use diffusors as apposed to absorbers BEHIND the speakers; on the front wall (as per what Bryan mentioned above).When you stated in your post not to use diffusion near the spekers, did you also mean behind them as well? What kind of acoustic material do you use behind your Maggies?
Barry:How would you "float" a pair of Maggies (or Apogees in my case)? Do you mean to use an inner tube on the floor and sandwich a piec of plywood between the tube and the spikes?
