0 Members and 1 Guest are viewing this topic. Read 23316 times.
It certainly is a preference. On most speakers, I'd agree, no diffusion behind. On a full range dipole like a Maggie or any electrostat, fully 1/2 of the output of the speaker is from the rear wave and we don't want to lose that output. It's part of what gives a panel speaker it's unique sound. Also, absorbing behind a full range dipole can minimize the natural bass cancellations to the side of the speaker.I do generally recommend absorption in between the speakers on the front wall. Bryan
http://forum.audiogon.com/cgi-bin/fr.pl?vevol&1188229613Coming late to this party... That's my front wall. I experimented with lots of configurations (pure absorption, pure diffusion) and found that a blend of them works best. Note the painted, mass-loaded D1 diffusion panels and GIK tri-traps. They work splendidly in my application.-- Nils
I use a similar setup to Nils with my dipoles (Linkwitz Orions) - absorption in the corners, diffusion at first reflection point on front wall moving to absorption directly between the speakers. My setup was arrived at through experimentation.
You don't absorb the back wave of a dipole... The dipoles need to be out "at least" 5' from the wall (at least 10 milliseconds of rear wave delay needed at your ears), and an untreated wall, or some small amount of diffusion if you must (usually when you can't get the 5' needed).
Intellectually I understand the theory that anything the room adds to the sound is detrimental because it wasn't on the original recording, but my ears prefer a spectrally correct, well-energized, diffuse, relatively late-arriving, slowly-decaying reverberant field... and dipoles set up properly in a suitable room do a very good job with this.
