0 Members and 1 Guest are viewing this topic. Read 23315 times.
How does your diffusion product compare, price-wise, with acoustic fiberglass panels? Also, what opportunities are there for DIY'ers? I have (22) 4'X8' acoustic panels in my room. How much would 176 square feet of your diffusers cost? No one here disagrees with diffusion. I would like some diffusers in my room. The problem is the cost. Just to replace the ( 8 ) panels on my ceiling with low/moderately-priced diffuser panels would cost $800.00 plus shipping. The four panels on my ceiling cost less than $50.00 each to make.
Fabric wrapped fiberglas panels are really low tech construction easily achieved by the DIY crowd.
Hi Dave,I would agree that one does not want to "absorb the back wave of a dipole". What needs absorption is not the back wave but the reflection of the back wave coming from the wall behind the speakers. Some folks like the coloration and sense of "added space" the reflection - or diffused reflection - appears to add. This is not the space contained in the recording, it is an artifact of the reflection.Just my perspective.Best regards,Barrywww.soundkeeperrecordings.comwww.barrydiamentaudio.com
One can orient the ribs vertically to trick the ear into believing the soundstage is wider (especially effective in a narrow room) Bryan
While we do not want to absorb the backwave of a dipole, we still need to address the potential comb filtering issues that the reflections off that wave from the wall can cause. The way to do that is through diffusion which will minimize the comb filtering without killing the wave's energy.One can orient the ribs vertically to trick the ear into believing the soundstage is wider (especially effective in a narrow room) or we can orient them horizontally, which will scatter in the vertical dimension and can increast perceived soundstage height.Bryan
There is no point in buying and owning a dipole speaker if you don't want that "added space" .....better to just buy monopoles, if thats your thing.
Quote from: flintstone on 15 Sep 2009, 05:11 pmThere is no point in buying and owning a dipole speaker if you don't want that "added space" .....better to just buy monopoles, if thats your thing.I prefered the quickness and clarity of ribbon/planars, which is why I went with Maggies. But I also don't want the "added space". Guess I'm just uniquely using my Maggies. I also still use a subwoofer because they can't produce the necessary bass (even "full-range" box speakers can't IMO). My sides are relatively open, so I probably don't have the same rear wave characteristics as other people.
Quote from: bpape on 15 Sep 2009, 06:35 pmWhile we do not want to absorb the backwave of a dipole, we still need to address the potential comb filtering issues that the reflections off that wave from the wall can cause. The way to do that is through diffusion which will minimize the comb filtering without killing the wave's energy.One can orient the ribs vertically to trick the ear into believing the soundstage is wider (especially effective in a narrow room) or we can orient them horizontally, which will scatter in the vertical dimension and can increast perceived soundstage height.BryanComb filtering is not a problem if you can set them up properly...again, at least 10 ms of delay. If you get the proper amount of delay of the rear wave, the ear detects it as just any other reflection....ie, rear wall, side wall...and not part of the direct sound. The direct sound should only be the front wave.Small room setup is a problem with dipoles, I agree with your point>Dave
Hi BarryThere is no point in buying and owning a dipole speaker if you don't want that "added space" .....better to just buy monopoles, if thats your thing.Dave
Hey Barry, I like your posts, I can identify, I am a studio dog as well! lol.....Well I subscribe to the theory that your room is part of your audio system, it definitely has a "signature" that you hear along with your mixes. Everyone knows that if you put a stereo in a gymnasium, it sounds a little bewildering, on the other hand I don't think anybody wants to listen in an anechoic chamber. Just sitting in one is like a vacuum on your ears! So what to do???? A dipole speaker is not my cup of tea, I like a point source. But if the speaker sends out an identical wavefront to the rear, how do you "get rid" of the reflection in a graceful way? If you build a Hidley full range trap five feet deep, is that the right approach? Or do you leave a flat sheetrock wall for them to bounce off of? I play a trombone professionally, and I can tell you I prefer the sound of a large diffuser coming back at me as opposed to a flat sheetrock wall..... So logically, I think the people that want the dipole sound, need to "get their money's worth" and have a pleasant, diffuse sound from their back wave. Hey man all of this is worth 2 cents, I know...lol....Allen Rumbaugh
BarryI couldn't disagree with you more, although I respect your opinion...and all others. It reads to me that you are a monopole box guy, with a dislike for dipole sound?, and you would take all dipoles, and turn them into monopoles (although that was not the designers intent)I understand that reflictions off of walls cause problems, but they are also the life of the music. The rear wave of a dipole is no different than any other room reflection...I take it you would absorb them all ?I have lots of speakers, small boxes, large boxes, fullrange dipoles, hybrid dipoles. I'll take the fullrange dipoles over them all...setup in my room as stated (I would NEVER absorb the rear wave, I've done it before as a test) That said...I don't mind if someone else wants to do it?...although I would never give them that advice. I would prefer they buy a different kind of speaker (some hybrids would be better).Dave
Hi Dave,Quote from: flintstone on 16 Sep 2009, 08:49 pmBarryI couldn't disagree with you more, although I respect your opinion...and all others. It reads to me that you are a monopole box guy, with a dislike for dipole sound?, and you would take all dipoles, and turn them into monopoles (although that was not the designers intent)I understand that reflictions off of walls cause problems, but they are also the life of the music. The rear wave of a dipole is no different than any other room reflection...I take it you would absorb them all ?I have lots of speakers, small boxes, large boxes, fullrange dipoles, hybrid dipoles. I'll take the fullrange dipoles over them all...setup in my room as stated (I would NEVER absorb the rear wave, I've done it before as a test) That said...I don't mind if someone else wants to do it?...although I would never give them that advice. I would prefer they buy a different kind of speaker (some hybrids would be better).DaveI spoke of absorbing early reflections, not all reflections.And not wanting to contaminate the information contained in a recording with arbitrary and artificially created "room" information in no way suggests monopoles.In making recordings and in evaluating recordings I mix or master, I need to hear the recording and only the recording. I feel the same way when listening for pleasure.When I make a recording, I spend a lot of time in selecting the venue in which the performance will occur. Different types of music require different spaces. For example, a vocal chorale might sound its best in a somewhat reverberant church. A solo classical guitar should be heard in an intimate setting. A jazz quintet or a rock band may require a certain type of auditorium. (I don't use studios, preferring instead to record in spaces that support the instrumentation in the context it is intended to be heard.)I use a special stereo microphone array, utilizing a matched pair of microphones and a special baffle between them, in order to supply all of the cues Nature has supplied us with for localization of sounds. When I'm lucky, the results give the listener the feeling they are in the room in which the performance took place. Soundstage dimensions and image size match what I hear from the position of the microphone array at the recording session.Adding the listening room to this equation would serve only to obscure the room that is in the recording as well as altering the soundstage dimensions and image placement.There is nothing like attending the original recording session to get a reference for how accurate (or not) the playback is.In the end, I suppose we must agree to disagree.Best regards,Barrywww.soundkeeperrecordings.comwww.barrydiamentaudio.com
I guess we disagree most on the early reflection thing, my advice is not an "early" reflection...the excepted norm is 10 millisecond "minimum" of delay for dipole rear wave delay. Anything less will not do.....enter the band-aid advice.Dave
