0 Members and 3 Guests are viewing this topic. Read 1203553 times.
By smaller I meant smaller than the 2.5 x 5 ft. My favorite is 4 x 2ft but I got to say the square 2.5 x 2.5 is growing on me - especially after I made a free hanging stand. Took down some of the hot character of the 30 exciter, not to mention the better WAF amd living room factor... not to be discounted in my house . Since we are talking smaller, I have had some success with small Al and Cu looking plates. 3" x 4". Of course only for the upper frequencies. I havent had a chance to integrate them with bigger panels yet
OB_NEWBIEI've just come from the diy shop and was examining the low grade eps ,some worse than others .They tend to have black bits in and gaps in the surface ,my main worry with this quality material is the contact with the exciter foot and unknown air gaps under the surface, a healthy amount of waterproof wood glue on the exciter foot and adjacent panel area would be a good idea ,I think,thick wood glue does not shrink like the pva and would hopefully fill any gaps,good contact with the whole of the panel surface is essential,other than that I can't see why it shouldn't perform well, Smaller panels like my 9x12inch 3mm xps panels don't really need supporting but do need a higher xo to be able the drive larger rooms .Using different types of frame for mounting will increase the lower end performance and help drive the room allowing a lower xo,but the cost will be a not so open sounding panel but they can sound good.This is a picture of the 9x12inch ,this is basically a base from a shop bought pizza,in fact all of my small panels were made from different sized and shaped pizza bases ,this was the only way I could get hold of the 3mm material,the only problem was the amount of weight I was putting on I a call them the pizza panels range You can see some in the background of this pictureMounting two on a single frame was good also, but does not exist anymore,the idea was to mount them in a large line array,I've still got all the panels,too many in fact Steve
OB_NEWBIEI should have pointed out that I do eat the pizza before mounting the exciter,there's a lot less mess that way A very understanding wife don't know we're that one came from!You try sneaking a speaker more than 4inches into the front room ,or a led zeppelin cd ,you'd think world war three had started,I have to make a hasty retreat back to my bomb shelter(music room) If I remember correctly,multiple panels or line arrays work best if listened to from a distance ,the cancellation affects between and in front of the speakers even out with distance.This is why I probably prefer single panels with single exciters in the smallish rooms I have.Steve
I bough various router bits and will be routing a round groove between the 2 panels... likely at an smallish angle to vary the response of the panel along with different exciter locations for what I hope is a smoother combined response. This should isolate those frequencies where cancellations would occur.As for the array aspects. In theory, a 2x6 panel with one exciter ought to operate the same as 2 - 2x3 panels assuming that the entire panel surfaces generate output. Though I have to imagine that a single panel would not have even output over its entire surface?!?! But there will be cancellation either way on both panels. Likely more HF cancellation on the 2 panel array but that depends on the listening distance where they would sum.I EQ the panels anyway so a slight drop in the HF won't be to much of an issue... hit the panels with a touch HF boost and I'm back in bidness.
Before you start to go routing everywhere,I think there are a few things you should know.Years back now,I had two 12x12inch eps panels on a 12x24inch frame,with a small gap between the free floating edges between them,at the time I only had one of the panels with an exciter on it.I then attached a small blob of bluetak about the size of a pea in the middle between the panels.The output from the panel without an exciter on it was pretty much the same as the panel with the exciter on it two panels for the price of one exciter (I'm sure manufacturers would love this).I might as well have straddled the two panels with the one exciter(now there's an idea)'The only way to stop one exciter interfering with another on the same panel is to saw it totally in half .You might change the modal pattern on the panel by routing because you have altered the rigidity,but you will not stop one side of the panel from exciting the other,it would be as if the routing was not there.A 6x2ft panel with one exciter on would have one point source ,two 2x3ft panels would have two point source's,a 6x2ft panel with two exciters on would also have two point source's on.Each exciter area in itself is nothing more than a flat cone speaker ,what happens to the panel after that first primary pulse is a bonus(dml)As for EQing a mechanical cancellation on the panel ,once it's gone it's gone,you can only EQ what's left,better not to cancel in the first place.I hope this helps.Steve
Cool. Looking fwd to hear about your results. Btw rightly or wrongly, I have always gone for the principle to gradually thin the panels towards the edge on large panels. Idea is the "energy principle" to make it easier to propagate the wave the further away from the source. Exception is thin at exciter location
I'm not sure about thinning the panel with eps as it would probably loose some of its rigidity,plus I haven't noticed any problems with the sound moving through eps,quite the opposite in fact.The 5mm xps I would describe as a lossy panel,heavily direct radiating with a not so high output dml mode,even more so when I sanded the outer 2inches or so,this helps soften the reflections I think.
I too am not keen on putting eps in frames ,but ply seems to benefit from it,there's more life and detail ,they are now more spacious sounding ,I'd go as far as saying these are the best nxt dml bmr panels I have ever heard (except for my poly +sub combo
