The way I see it is that mounting the panels with small foam squares in the corners and 2 on the sides is all that is needed. This works and works well.......very simple, very cheap...and most importantly, does NOT affect or over dampen the panel's resonance at bass frequencies.With ''voice coil creep'' (voice coil misaligning itself due to the weight of magnet), I have had my panels in the same position for many months now and there has been no audible effects of this.However, you can see a slight tilt from 90 degrees from the vertical.Answer...........very simple.........make a panel frame that can be turned upside down twice a year or so. Design it so that the feet of the panel can be removed and mounted at either the top or bottom of the frame Like I've said though........I am yet to hear any negative sonic degradation to this problem if it will ever occur.I say go for anything that you think will work. But make it reversible should something go wrong.We are dealing with an unusual technology here, so going to any complexity may be going in the wrong direction - a mistake that has been made by many high end designers in the past.Let's not forget that
I'm curious about the function of width with these panels. Common sense tells me that wider would also help give more bass - however common sense also told people the earth was flat. Anybody do any comparisons on what increasing the width of these panels does?
* Harmonic dampening characteristicsThe Harmonic dampening characteristics make we wonder if this is good or bad for a music panel.
I believe that the difference is to do with the spacing between the exciters and how many will fit on a certain sized panel within that ''spacing''.There is something to this spacing of the exciters. I just don't know what. Podium have the right to keep this information secret, and rightfully so.
