0 Members and 7 Guests are viewing this topic. Read 1213855 times.
Woooooah!!!..........HOLD ON TO YOUR HORSES GENTS!.......a lot of these modelling programs and application documents/patents are for panels that are held firmly or even clamped by all edges, such as hanging picture frames etc.This is the actual NXT original application design notes. This is totally different to The freely suspended panel like the Podiums and my DIY project.
Quote from: FULLRANGEMAN on 28 Aug 2009, 06:35 pmQuote from: doug s. on 28 Aug 2009, 06:18 pmQuote from: FULLRANGEMAN on 27 Aug 2009, 05:38 pmThe Dayton DAEX25 Sound Exciter is in stock again at PartsExpress, same price $16,90/16,00 earchhttp://www.parts-express.com/pe/pshowdetl.cfm?Partnumber=300-375why not get the cheaper ones?http://www.parts-express.com/pe/showdetl.cfm?Partnumber=309-148doug s.I afraid of cheap products, maybe he feels so. I would like to know whait is the best? The dayton or the other white cap exciter? Before buy anything.RegardsIn my opinion the cheap ones look just like the ones that Zygadr used. The numbers by the voice coils are similar, but not exact too. The only concern I have about the cheaper ones is that they are 4 ohm, which means a lower amp load if you try to parallel multiples of them together. Of course I really don't know how much parallel vs. series connections affect sensitivity with this kind of panel driver. Does anyone know if parallel connections increase sensitivity as they do with pistonic drivers sharing a baffle? Also, if you parallel some together, but then have to series connect a couple of paralleled groups together, does that diminish any sensitivity gains you might have gotten from the paralleled exciters?
Hi Fullrangeman, Gatorfoam is a product that has been around for years. Sign companies often use it for displays and signs. I got mine from a company that sells plastics such as coroplast. I believe you could order the exciters from Parts Express. They ship to other countries. I'm in Canada and mine came by mail. Hope this helps. Jim
I wonder what 2 full size 8 foot X 4 Foot panels of Gatorfoam with 12 exciters per side would sound like??? .............................JUST KIDDING!!
