0 Members and 7 Guests are viewing this topic. Read 1214166 times.
I wouldn't mind investing in gathering a bunch of materials, if it was clear what the key mechanical properties of the materials were WRT bending waves. Then it's a case of gathering a range and seeing what correlates with the "best" sound.
use fishing line attached to the four corners of the panel(tied through small holes drilled in the corners?) and then tie these to the dowel posts with a few inches of line separating the panel from the posts. The ends of the posts can be grooved to stop the line from moving about.
On second thought, could they mean 4/9ths of the width and 3/7ths of the height? Sounds unlikely to me, but maybe that's it.
Quote from: HenryPercy on 2 Oct 2009, 01:49 amOn second thought, could they mean 4/9ths of the width and 3/7ths of the height? Sounds unlikely to me, but maybe that's it.This position data are intended for when you are using just one exciter. Why they always think people will use just one exciter with just 6W!!
The instructions indicate positions for 1,2,3 and 4 exciters on a panel. Do you know how to interpret them?
Quote from: HenryPercy on 2 Oct 2009, 02:14 amThe instructions indicate positions for 1,2,3 and 4 exciters on a panel. Do you know how to interpret them? I think yes, this coordinates are fractions of the width and height of the panel. They not info the width and height of the panel, because this is for you choose.Like all exciters will be in the middle vertical of the panel, the first thing you will calc is the distance from the first exciter and then just go ahead, because all exciters are the same distance from each other.Dayton do not know all exciters must stay in the vertical middle of the panel like the Podium speakers, for this they info two coordinates on this paper. Do you get ?What is the size of your panel??How many exciters you will use in each panel??
I have two panels of Gatorfoam, each 4' x 8'. I plan to cut them down, but I have no idea what size is best. Of course, I could use them as is, but my wife wouldn't like it one bit.I have 16 exciters, but I could use less, or buy more, whatever gives optimum results. I plan to experiment a lot.
UHH! You have two full sizes GatorFoam panels!! So if you will cut the panels I can not help in this small panels sizes/exciters.But if you could use a large panel, I can give you my owns plans for my project.This is: Panel wide= 75cm, panel High= 196cm (Golden Ratio)All eight exciters in the vertical middle like the Podium, Final Impedance= 4 ohms, Serie-Parallel (set 1, parallel=8+8+8+8=2ohms, set 2, parallel=8+8+8+8=2ohms, total= 2+2=4ohms)Exciters Positons, Option ONE= 1? exciter at 21cm from bottom (21, 42 63, 84, 105, 126, 147, 168cm, rest 28cm to top.Exciters Positons, Option TWO= 1? exciter at 23cm from bottom (23, 46 69, 92, 115, 138, 161, 184cm, rest 12cm to top.My project for eight exciters this is it!! Anyone fell free to comment...Dear Henry: Another option: In 1987 I kickout my first wife for want command in my audio hobby.
The reason I ask is that looking at a Chinese manufacturerswebsite shows a dozen or so 25mm models, but their free air resonance varies between 230 - 500Hz. Are there any specifications on the two models most of us are looking at. Pardon my ignorance, but what does "free air resonance" mean?Never mind. I found it.The other thing I noticed was the white Gatorfoam has superior compression strength, elastic modulus and bending strength for the same weight, compared to black. Probably unimportant , but if colour isn't critical, white may be better.Interesting. Could you post a link to that information? Thanks.
