The speaker project (dialup warning)
0 Members and 1 Guest are viewing this topic. Read 35920 times.
JoshK
Re: The speaker project (dialup warning)
« Reply #100 on: 5 Dec 2011, 03:39 pm »
Now that I am settled in up in Toronto, I am now re-thinking of how to setup the big horn system.  First I need to build stands.  Its not an easy solution.  The big horns are quite heavy and awkwardly weight distributed.   Any ideas you guys might have would be appreciated.
Josh
jtwrace
    • TIPP YouTube Channel
« Reply #101 on: 5 Dec 2011, 03:47 pm »
Did you move for work?  Do you like it compared to NJ?
JoshK
« Reply #102 on: 17 Dec 2011, 05:25 pm »
yeah I moved for work.  Toronto is a neat city but its no NYC.   I do like that it isn't as crowded and rent is more reasonable.  Everything else tends to be more expensive.
JoshK
« Reply #103 on: 9 Sep 2013, 09:00 pm »
I am selling the big horns (140hz LeCleach) if anyone is interested.  I don't have the space to set them up properly.  I am in Toronto.
