0 Members and 1 Guest are viewing this topic. Read 124791 times.
have you tried playing with the loading caps and resistors?If you mean replacing them, I have not. I do have the Dip Switch chart and currently am at 230 for my Kleos. I have even tried a few different capacitance setings.On further listening, it sounds more like an elevated shelf from about 1k to maybe 5k or so. Even with the 5751's it does not have the output on the very top of my GCPH but I can live with that for now. As my room and ears are sensitive to peaky mids and lower treble, this is annoying.Thanks for your reply,Robert
I would try the LT1028acn opamp in the 5,6 positions with reference to the pic below. In my system, I have found these to possess the most clarity. Thanks for that. I will try them. Any US suppliers that will sell only 2? What I am finding is the LT1028ACN8 .BTW, clarity is not my issue and all the specs talk about low noise which is also not my issue. Peakiness is the issue.That board is under one of the metal covers? Where?Thanks Again,Robert
The board is under the large rectangular cover near the input rca jacks. 4 screws. the op amps are in sockets so replacing them is a breeze. Digikey is a good source. Sorry I cant address your peakiness issue directly, not hearing what your hearing.
PS: Is bigdirty related to John Bigboote? Pronounced big boo tae, despite Lazardo calling him bigbooty.
I googled this... thank you. To the video store!
don't forget: wherever you go, there you are! doug s.
Mine has a bit of "Bloom" that on some records is awesome and a bit much if they were a bit forward to start with. Mine is in the upper midrange/lower treble area. Tubes helped and I'm going to change caps.Hibuck....
